Old 07-25-2013, 12:14 PM   #1
qganja
qganja's Avatar
Drives: 10 series frs
feeling a sway on the rear end
hi guys, im a new owner of frs and a car virgin. i have an issue with it. on the freeway doing 70-75 i could feel a "sway" on the rear end. is it the road being uneven or is there something wrong with the frs? everything is stock. hope someone could shed some input, thank you.
qganja is offline   Reply With Quote
Old 07-25-2013, 12:16 PM   #2
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
the car is really light and comes with shitty tires. it gets worse with uneven pavement.
what did you drive before the frs?
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Old 07-25-2013, 12:30 PM   #3
Luis_GT
I think the spoiler helps the car... I have the Scion spoiler and have taken the car up to a buck five and it's planted... even on crappy roads... that said... any steering input and you'll feel it... even if it's a .001 degree change... at 80 it feels as stable as an M3, and a lot more stable than my E39 which sways around a lot at 85...
Old 07-25-2013, 12:42 PM   #4
jflogerzi
jflogerzi's Avatar
This is normal. I remember my car when it was brand new, it did this on freeways where it was concrete type and not asphalt paved type.
Old 07-25-2013, 12:53 PM   #5
bear89103
Old Fart
bear89103's Avatar
It's probably the groove lines on the freeway. I experienced this too until I chnaged my wheels and tires.
bear89103 is offline   Reply With Quote
Old 07-25-2013, 01:32 PM   #6
qganja
qganja's Avatar
an accord 07 coupe.
Old 07-25-2013, 01:35 PM   #7
qganja
qganja's Avatar
i might try adding a spoiler before changing the tires first. it gives me creeps going faster knowing the stability they said.
Old 07-25-2013, 01:37 PM   #8
kALMIGHTY
Drives: TRD Ultramarine '13
I have the Scion spoiler too and I've taken it up about 160 km/h with no "sway". I think the spoiler actually is functional despite it's relatively small size, and the car feels planted.
Maybe get a spoiler if it worries you? I actually think the Scion spoiler looks awesome on the car. It's almost as if it's a perfect blend between the GT86/BRZ Limited spoiler and the Five Axis spoiler.
Old 07-25-2013, 02:21 PM   #9
FRiSson
Drives: FR-S MT
Don't run out and get a spoiler. They don't have any effect until the car is well over the speed limit. First of all, check the tire pressure, this can have a surprisingly large effect. Second, there is a possibility that a tire is bad, slipped belt, etc..
But, before you check that out, drive the car a while longer to get used to it. It will drive differently than an accord, especially an older car that has gotten quirky with age.
FRiSson is offline   Reply With Quote
Old 07-25-2013, 02:35 PM   #10
qganja
qganja's Avatar
yeah! i need to drive it still longer, still in the break-in period. thank you guys for your opinion, great help...
Old 07-25-2013, 02:39 PM   #11
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Did you do exhaust? The factory muffler acts as a aero device. I can feel the difference at high speed in stability.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 07-25-2013, 03:56 PM   #12
qganja
qganja's Avatar
no. all are stock also the exhaust.
WTB:OEM BR-Z REAR SWAY BAR Ryeong86 Want-To-Buy Requests 1 09-04-2013 04:40 AM
USED Rear Sway Bar - need opinion! Ravenlokk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-20-2012 06:31 PM
WTB: Stock WRX 16mm Rear Sway Bar NYC BRZ Cars for Sale/Trade 3 09-01-2012 06:36 PM
AMT rear sway bar bracket adamturbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-13-2012 11:06 AM
STI rear sway bar carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-25-2012 12:58 PM
