Old 07-25-2013, 03:04 AM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
racerom flat foot shifting
so i've noticed on some vids, the rev limiter is kicking in on flat foot shifting. on mine, it just shifts into the next gear without it hitting the limiter. am i doing something wrong? do i need to set rev limiter to a higher number ?
[ame="http://www.youtube.com/watch?v=BA8qrWMwYH8"]http://www.youtube.com/watch?v=BA8qrWMwYH8[/ame]
ft86me is offline   Reply With Quote
Old 07-25-2013, 08:40 AM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
What version of the visconti tune are you running?
I did notice with the supercharger and an older tune that flat foot shifting would sometimes just cause the revs to "hang" without activating the limiter.... usually only happened when revs were above 4K or so
With 1.06 it seems like its working like it did when NA, maybe due to different race rom version from previous tune
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
ft86me (07-25-2013)
Old 07-25-2013, 11:00 AM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
Currently on 1.06 and I think I figured it out. Depending on where you set your launch control is where it'll blip when flat footing. So that's what it seems like
Old 07-25-2013, 11:14 AM   #4
DJCarbine
Thupercharged
DJCarbine's Avatar
Really?
Mine always just "rev limits" at the rpm that I push the clutch in at
2013 FRS
Vortech V3 11psi
Old 07-25-2013, 11:17 AM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
Really?
Yeah it's so weird otherwise it'll just shift without doing the blip thing. I wonder what's going on with it
Old 07-25-2013, 11:18 AM   #6
ft86me
ft86me's Avatar
Drives: 2013 FRS
Really?
I actually tried it out and at 4.5k is my launch control limiter and when I had it floored I pushed the clutch in the jumper to 4.5 and was bouncing on the limiter. Maybe I should try it higher and see how it is after like 5. Hopefully the revs don't jump to red though
Old 07-25-2013, 11:32 AM   #7
Norcalmav23
Drives: SWP Limited manual BRZ
what you are describing is definitely not happening in my car... I am using the most current stg 1 visconti tune that was released about a week ago. For me... regardless of rpm it holds it there for that brief moment where the shift is supposed to happen.
Norcalmav23 is offline   Reply With Quote
The Following User Says Thank You to Norcalmav23 For This Useful Post:
ft86me (07-25-2013)
Old 07-25-2013, 11:34 AM   #8
DJCarbine
Thupercharged
DJCarbine's Avatar
This is what mine does as well
2013 FRS
Vortech V3 11psi
ft86me (07-25-2013)
Old 07-25-2013, 11:35 AM   #9
ft86me
ft86me's Avatar
Drives: 2013 FRS
Hmm maybe I should hit up Visconti
Old 07-25-2013, 02:59 PM   #10
DJCarbine
Thupercharged
DJCarbine's Avatar
Found this in the racerom manual
"At the moment when the Flat Foot Shifting feature activates, a temporary rev limit is set thatis slightly higher than the current RPM. The ignition timing is retarded by a specified amountthat reduces engine torque while preventing the RPM from rising too rapidly."
2013 FRS
Vortech V3 11psi
ft86me (07-25-2013)
Old 07-25-2013, 03:02 PM   #11
ft86me
ft86me's Avatar
Drives: 2013 FRS
Hmm well should it be doing what it does I'm te vid?
EcuTek RaceRom Questions. feldy Engine, Exhaust, Transmission 7 02-12-2014 04:07 PM
EcuTek racerom feature help lbroskee Engine, Exhaust, Transmission 10 05-08-2013 10:45 AM
RaceROM Features Demo'd JPxM0Dz Engine, Exhaust, Transmission 13 03-26-2013 09:39 PM
EcuTek RaceRom Flat Foot Shifting ! Visconti Engine, Exhaust, Transmission 79 11-14-2012 09:36 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
