Old 07-24-2013, 01:04 PM   #1
Jayde
Jayde's Avatar
Vibration feedback through steering wheel.
Recently I've notcied a vibration coming through the steering wheel. Can't tell you if I've always had it or im just being ocd, but it's very minimal and rarely ever does it vibrate enough to move the steering wheel. Keep in mine it does not affect which way the wheels face, it's just a vibration. Is this just cause the car gives excellent feedback and I'm just now noticing it or could it be worse? I've checked for rocks as well as tire pressure and both are fine.
Jayde is offline   Reply With Quote
Old 07-24-2013, 01:07 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
you should provide more info, such as:
- speed
- road type/condition you're driving on
- cruising, acceleration, or deceleration?
- etc
-alex
Old 07-24-2013, 02:28 PM   #3
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
- speed
- etc
-alex
This. There's not enough info. If vibration is increasing with speed, it could be the wheels need to be rebalanced. Under braking, it could be due to uneven brake pad material deposit on the rotors. There's too many unknown variables.
G_Ride is offline   Reply With Quote
Old 07-24-2013, 02:58 PM   #4
mav1178
mav1178's Avatar
Could also be:
- wheel out of balance
- wheel lugs loose
- bad steering rack
- bad shock
- uneven tire wear
etc etc
-alex
Old 07-24-2013, 04:00 PM   #5
Jayde
Jayde's Avatar
- speed
- etc
-alex
Could also be:
- wheel lugs loose
- bad steering rack
- bad shock
- uneven tire wear
etc etc
-alex
Apologies for the lack of info. I typed it up just before I went back to work. Had a coworker take a look and he says it's just normal road vibration. I'm driving a friend's BRZ after work to see if it's the same. I'll provide more info about what you guys posted when I get home. Thanks so far!
Old 07-25-2013, 10:19 AM   #6
Jayde
Jayde's Avatar
- speed
- etc
-alex
Vibration doesn't increase or decrease with speed or load on the engine. Happens on both smooth paved road as well as bumpy ones.
Could also be:
- wheel lugs loose
- bad steering rack
- bad shock
- uneven tire wear
etc etc
-alex
Checked torque on the lugs and they were good. I drove my buddies brz last night and while his does have the same vibration, it wasn't as noticeable. Then again his has 10k less miles. He drove mine and didn't notice anything different between the two. He says its all in my head. Its likely just more road noise due to more wear on the tires.
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Even the Yaris has Tokico HP shocks? Also any Steering feedback iprovements. regal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-21-2013 09:41 PM
So, just how good is the steering feedback? nedmundo Scion FR-S / Toyota 86 GT86 General Forum 54 11-07-2012 06:27 PM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
