Old 07-23-2013, 03:31 PM   #1
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Oil gauges and oil cooler ?
I have oil pressure and oil temp gauges running off a sandwich plate.
Next mod up, is my Perrin Oil Cooler but I'm unsure as to how to engineer it alongside the gauge sandwich set up.
Any thoughts?
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
The Following User Says Thank You to ICantAffordAnLFA For This Useful Post:
bgibbsunc (07-23-2013)
Old 07-24-2013, 03:23 PM   #2
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
Im wondering the same. Im sure I will find a place but am down for a good lead.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 07-24-2013, 03:26 PM   #3
bgibbsunc
bgibbsunc's Avatar
Maybe you should have posted this in the FI section. Since most na guys wont be running gauges.
San Antonio TX
Old 07-24-2013, 03:31 PM   #4
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Stack them. I have mine like this:
Oil filter
Sandwich plate for gauges
Oil cooler thermostatic adapter
Perrin spacer
BatStig is offline   Reply With Quote
Old 07-24-2013, 03:55 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I don't think I would want the stack to get any higher than it is with a spacer and oil cooler adapter. I would drill and tap the oil cooler adapter or spacer for two 1/8 NPT ports for your gauges. It would have been nice if they came that way with plugs installed for those that don't want to use them.
Old 07-25-2013, 12:15 PM   #6
bgibbsunc
bgibbsunc's Avatar
I dont want to stack either. Someone should do a diy on this. Oil cooler, oil temp gauge, and oil pressure gauge. Ill be installing mine next month. If I think to and have the time Ill do a DIY
San Antonio TX
Old 07-25-2013, 01:50 PM   #7
brz_star21
Drives: DGM BRZ
What kind of sandwich adapter are you running? If it doesn't have sufficient ports, maybe this Blitz setup might give you ideas to add fittings or to find a similar sandwich adapter setup.
Scroll down towards the bottom of the page for the pics. There are provisions for a temperature port and 1/8 NPT pressure port on the fitting depending on the size.
Blitz Oil Cooler
brz_star21 is offline   Reply With Quote
Old 07-26-2013, 02:37 AM   #8
ICantAffordAnLFA
Drives: Brz, Legacy
Blitz Oil Cooler
Not seen that before, thanks
Old 07-30-2013, 07:49 PM   #9
BatStig
Some say.....
BatStig's Avatar
I will be changing my stack from what I posted above.
I got my hands on a TRD sandwich plate for the sensors and it's just tall enough that I can use it in place of the spacer supplied with the Perrin oil cooler kit.
So, my stack will be:
Filter
TRD plate
I'll post a pic up next week.
Old 07-30-2013, 08:07 PM   #10
mrk1
Drives: Sterling BRZ Ltd
I would think theres got to be some oil galley plugs that can be adapted for sensor use like on the EJ motors. Look at where the FI guys are pulling for oil feed lines could be a clue.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-30-2013, 10:51 PM   #11
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Filter
TRD plate
Where did you source the Trd plate and what's the part number.
Thanks
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 07-30-2013, 11:00 PM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes there is... I use it for Oil pressure gauge, its right in between the intake and the AC compressor, there are pics floating in the forum, will find you one
Edit:
Here it is.... http://www.fastwrx.com/oilgalleryplug.html
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
448hpsti (09-15-2013), van_fc3s (04-26-2014), WolfsFang (07-30-2013)
Old 07-30-2013, 11:35 PM   #13
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
It looks like this oil adaptor has 4 ports in it for everything.
http://prosportgauges.com/oil-filter-adaptor-plate.aspx
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 07-31-2013, 12:15 AM   #14
BatStig
Some say.....
BatStig's Avatar
Thanks
TRD: SENSOR ATTACHMENT FOR OIL GAUGE : MS131-18001
http://www.japanparts.com/db/parts_d...=28&submit.y=9
The Following User Says Thank You to BatStig For This Useful Post:
Brzzee (07-31-2013)
Cyberstork gauges ANREX Cosmetic Modification (Interior/Exterior/Lighting) 53 08-11-2016 06:07 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 12:04 AM
Ecu and displays/gauges stockysnail Engine, Exhaust, Transmission 7 03-02-2013 06:23 PM
gauges where the radio is? J-Money Cosmetic Modification (Interior/Exterior/Lighting) 7 02-05-2013 10:11 PM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
