Old 02-04-2013, 07:55 PM   #1
J-Money
J-Money's Avatar
Drives: GT-86
gauges where the radio is?
Anyone know where to get the cover and the gauges that replace the radio? thats prolly the best spot and get an aftermarket radio in the cubby hole infront of the shifter
J-Money is offline   Reply With Quote
Old 02-05-2013, 12:12 PM   #2
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Or another option would be to do an aftermarket single din and instead of a cubby hole under the radio you can do 52mm gauges underneath. Here's an install I did in an a6 since theres no gauge mount solutions for it.
PrimeMotoring is offline   Reply With Quote
Old 02-05-2013, 01:05 PM   #3
I was just looking at this on japanparts.com.
Old 02-05-2013, 01:28 PM   #4
J-Money
J-Money's Avatar
Drives: GT-86
Yup this is what im talkin about! TRD has one i believe and another company
Old 02-05-2013, 02:30 PM   #5
I like this, the more gauges the better, but just can't do without the radio, and wouldn't like 1DIN in the bottom position. What I would prefer is a set that replaced the useless analog speedo, or a radio that supported native nav and a gauge cluster through BT.
Old 02-05-2013, 07:03 PM   #6
J-Money
J-Money's Avatar
Drives: GT-86
I do like @PrimeMotoring's Way of a top mount radio. But id love all a 6 gauge slot. if im going turbo it would be fun. Radio wouldnt bee bad in the cubby slot. if its connectd to pandora the whole time..
Old 02-05-2013, 10:00 PM   #7
Hardrock4445
Hardrock4445's Avatar
I forgot what company, but there is one that replaces the center dash vents and has room for 3 gauges there. Looks killer and its such a small car use the uppers or lowers and you'll be fine.
Hardrock4445 is offline   Reply With Quote
Old 02-05-2013, 10:11 PM   #8
CaptainSlow
CaptainSlow's Avatar
Will probably be WAY easier (and cheaper) to make one yourself. You can always relocate the radio to the glove box...wiring should be fairly straight forward, since it's basically right there anyway
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Cyberstork gauges ANREX Cosmetic Modification (Interior/Exterior/Lighting) 53 08-11-2016 06:07 PM
Do any aftermarket radio/nav systems offer gauges ? brillo Electronics | Audio | NAV | Infotainment 9 12-22-2012 02:03 AM
Software Gauges shirouxkamui Electronics | Audio | NAV | Infotainment 1 08-12-2012 10:30 AM
Radio, Iphone?? Radio cuts out when surfing the web Fugazi Electronics | Audio | NAV | Infotainment 5 07-30-2012 11:24 AM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
