Old 07-20-2013, 03:06 AM   #1
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Advice for a first time modder
I am new to modding since the BRZ is my first car. I want to lower the car around 20-30mm but still keep the suspension nice and not feel EVERY bump in the road. I've heard the Eibach Pro Kit works well, but I still want to hear opinions. Thanks!
Old 07-20-2013, 03:07 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Rce springs is my advice
86_ZN6 is offline   Reply With Quote
Old 07-20-2013, 03:10 AM   #3
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
IMO you cant go wrong with either eibach, RCE, swift etc. You might want to go with RCE just because of the bump stops, but i chose swift since they're in cali and they have a good rep with STi's.
bkblitzed is offline   Reply With Quote
Old 07-20-2013, 03:17 AM   #4
ChandlerSwyng
I'm pretty torn between the Eibach sportlines and the RCE yellows..
Old 07-20-2013, 03:23 AM   #5
bkblitzed
is better than you
bkblitzed's Avatar
i say rce because of the bump stops. It'll save some life on your struts.
Old 07-20-2013, 03:26 AM   #6
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
RCE Yellow are the best for comfort and performance. I have the Pro-Kit and Sportlines and they are too bouncy and don't handle as well as the RCE Yellows. The Sportlines look the best however but I'm a function > form kind of guy. H&R are very similar to the Eibachs so expect similar return on investment.
stockysnail is offline   Reply With Quote
Old 07-20-2013, 03:34 AM   #7
ChandlerSwyng
I read that the sportlines aren't very bumpy on review threads, how bad is it?
Old 07-20-2013, 01:59 PM   #8
stockysnail
Just the tip
It's not too bad, but noticeable. I'm picky though so you may not notice it as much. Larger bumps are definitely more harsh and noticeable however.
Old 07-20-2013, 08:36 PM   #9
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
just do Ohlins Road and Track full set up and its butter smooth
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
Overland'n'5thGEN (07-20-2013)
Old 07-21-2013, 09:30 AM   #10
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
Ohlin's suspension set up = $3k+ ?
RCE or Eibach Springs $250 ?
Completely different boats buddy
Enraged21 is offline   Reply With Quote
Old 07-21-2013, 10:18 AM   #11
Calum
That Guy
Drives: 2013 asphalt FRS MT
RCE is the only company I know of that changes the spring rates to match the roll rates at the lowered height. Everyone else just stiffens the springs a similar amount front and rear. This would be fine on a car with struts front and rear, or multi link front and rear. But that's not the case with this car. Lowering a multi link like in the rear of our cars, helps the roll centre. But lowering a strut suspension makes the roll centre higher, thus requiring the lowering springs to be stiffer then multi link lowering springs all else being equal. Also, this car is very bump stop happy from the factory. Again RCE takes care of this with their spring rates. On top of that, the RCE yellows only lower the car 20 mm. Not much if your main concern is appearance, but if your worred about performance this doesn't cause bump steer issues. Also the spring rates and heights will work well with the stock dampers. I really can't think of a compelling reason to go with any other company for lowering springs.
The Following User Says Thank You to Calum For This Useful Post:
Racecomp Engineering (07-21-2013)
Old 07-21-2013, 02:40 PM   #12
RehabJeff86
And the result is also different boats buddy - butter smooth when you hv properly valved shocks - the best 3.7k u can spend on the car:happy0180:
Old 07-21-2013, 04:56 PM   #13
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Even with aftermarket strings and stock shocks you're going to eventually change the shocks...and maybe the springs depending which ones you get.
Some advice zoomzoomers Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-22-2013 05:16 PM
2nd car advice zygrene Other Vehicles & General Automotive Discussions 38 02-19-2013 10:29 PM
First Time Driving Manual Transmission...Need Advice! Veloist Off-Topic Lounge [WARNING: NO POLITICS] 30 01-02-2013 12:22 PM
Need advice.. Help.. tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 9 08-13-2012 08:57 PM
FR-S or BRZ? Need some advice Davie Dynamite Scion FR-S / Toyota 86 GT86 General Forum 60 07-13-2012 10:47 PM
