Drives: Vortech Supercharged FR-S
I twisted off this screw yesterday, cuz I did not check the manual and used 40f/p to twist it. I did not realize it is M8 and thought that it was as big as those on the shock。
I was thinking to drill it out and get a new one from Home Depot. However there is no space on the back side to allow me put in a new screw. Any one can help me? I knew I could drive without this screw, or even without these two OEM bars. But does this screw affect a lot if I just let it like this? BTW, I may go to track in the future and do not want this screw affects the balance of this car. Thank you so much。
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
Drives: DGM BRZ-L
That bolt seems attached to the inner fender and not to any suspension components. There are three other bolts holding that bar on so you should be okay temporarily but I would try and find a fix if possible.
I am thinking to order a factory crew, but just could not find it. and also there is no space on the back to put a new screw in, even if I drill the bad one out.
Drives: Attitude
No, you are not the first.
Drives: Attitude
Thats kinda sad
。。I am lookin for someone who has done this before。
Drives: Attitude
#9 | |
lol this is worse. I was thinking to keep mine like this. I tried but can not drill out that screw. it was blocked.
#10 |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Being that the torque spec is like 12 ft lb, that's barely hand tight. Yea I've seen others take that off.
#11 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#12 |
Drives: Hyundai Elantra
Grind it down and find a new bolt cut the hex head off and weld the bolt on it will work this happens all the time with cars.
#13 |
Gotta learn the feel of what's tight and too tight its an acquired skill no offense
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#14 | |
Drives: Scion Fr-s
I've used it in the past and works great, good luck |
| Wheel Directory: Porsche Turbo Twist II 18x10.0 +15 /18x11.0 +25 | SLICVIC | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 84 | 05-31-2016 12:36 PM |
| FS: Porsche Turbo Twist II | SLICVIC | Wheels and Tires | 10 | 07-10-2013 01:52 PM |
| Another headlight black out, with a twist. | Hardrock4445 | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 01-16-2013 03:26 PM |
| New twist to the badges | Derik210 | Cosmetic Modification (Interior/Exterior/Lighting) | 39 | 01-08-2013 10:24 AM |
| Panman's GTS Aero - with a twist | Panman | AUSTRALIA | 31 | 09-27-2012 09:02 AM |
