Old 07-18-2013, 06:55 PM   #1
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Smile HEEEELP! Am I The FIRST ONE Who Twist off This Screw on FR-S? Someone Help Me Plz.
I twisted off this screw yesterday, cuz I did not check the manual and used 40f/p to twist it. I did not realize it is M8 and thought that it was as big as those on the shock。
I was thinking to drill it out and get a new one from Home Depot. However there is no space on the back side to allow me put in a new screw. Any one can help me?
I knew I could drive without this screw, or even without these two OEM bars. But does this screw affect a lot if I just let it like this? BTW, I may go to track in the future and do not want this screw affects the balance of this car.
Thank you so much。
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 07-18-2013, 07:00 PM   #2
ajcacio
Drives: DGM BRZ-L
That bolt seems attached to the inner fender and not to any suspension components. There are three other bolts holding that bar on so you should be okay temporarily but I would try and find a fix if possible.
ajcacio is offline   Reply With Quote
Old 07-18-2013, 07:02 PM   #3
Figo
Figo's Avatar
I am thinking to order a factory crew, but just could not find it. and also there is no space on the back to put a new screw in, even if I drill the bad one out.
Old 07-18-2013, 07:05 PM   #4
OrbitalEllipses
Drives: Attitude
No, you are not the first.
Old 07-18-2013, 07:06 PM   #5
Figo
Figo's Avatar
So are u another lucky guy?
Old 07-18-2013, 07:07 PM   #6
OrbitalEllipses
Drives: Attitude
No.
Old 07-18-2013, 07:21 PM   #7
Figo
Figo's Avatar
Thats kinda sad。。I am lookin for someone who has done this before。
No.
Old 07-18-2013, 07:32 PM   #8
OrbitalEllipses
Drives: Attitude
http://www.ft86club.com/forums/showthread.php?t=26254
Did you do your due diligence?
Old 07-18-2013, 08:12 PM   #9
Figo
Figo's Avatar
lol this is worse. I was thinking to keep mine like this. I tried but can not drill out that screw. it was blocked.
Old 07-25-2013, 09:56 AM   #10
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Being that the torque spec is like 12 ft lb, that's barely hand tight. Yea I've seen others take that off.
F1point4 is offline   Reply With Quote
Old 07-26-2013, 01:29 PM   #11
mad_sb
Drives: 2013 Asphalt FR-S
not gonna have much luck building your own car if you can't fix a sheared off stud
Old 07-27-2013, 11:23 AM   #12
jmmay
Drives: Hyundai Elantra
Grind it down and find a new bolt cut the hex head off and weld the bolt on it will work this happens all the time with cars.
jmmay is offline   Reply With Quote
Old 07-27-2013, 12:14 PM   #13
charged86
charged86's Avatar
Gotta learn the feel of what's tight and too tight its an acquired skill no offense
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-27-2013, 12:55 PM   #14
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Go to home depot and get this http://www.aldn.com/Pages/grabitPro.php
I've used it in the past and works great, good luck
Juanito08 is offline   Reply With Quote
Wheel Directory: Porsche Turbo Twist II 18x10.0 +15 /18x11.0 +25 SLICVIC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 84 05-31-2016 12:36 PM
FS: Porsche Turbo Twist II SLICVIC Wheels and Tires 10 07-10-2013 01:52 PM
Another headlight black out, with a twist. Hardrock4445 Cosmetic Modification (Interior/Exterior/Lighting) 32 01-16-2013 03:26 PM
New twist to the badges Derik210 Cosmetic Modification (Interior/Exterior/Lighting) 39 01-08-2013 10:24 AM
Panman's GTS Aero - with a twist Panman AUSTRALIA 31 09-27-2012 09:02 AM
