Old 07-13-2013, 03:47 PM   #1
jybrd
jybrd's Avatar
Drives: 2013 Scion FRS
UniChip vs EcuTek
Ok so I have again been doing a ton of online research. I want to get some personal opinions on Unichip vs EcuTek. If you have used both I would really like to hear from you.
A background on my car and I. My car has an Airaid intake a Nameless Axel back exhaust and a perrin pulley. I personally havent done any tuning in my life so this is new.
jybrd is offline   Reply With Quote
Old 07-13-2013, 04:02 PM   #2
KVDB31
KVDB31's Avatar
Drives: 2013 FR-S Asphault
I got the unichip and I'm very happy with it. I didn't have to pay labor for any shop, and it's fun to tweak the maps and try to get the best power out of it. The gains are pretty even across the RPM band, and I can really feel the extra punch coming out of corners getting back in the throttle. I would recommend t as long as you are able to install yourself.
Also the customer service and the response time from Jack was outstanding, as he was able to answer a bunch of questions I had before purchasing.
TSW Nurburgring 18x8, BFG Comp-2 235/40, KW V3's w/ Vorshlags, ECUTek by Evasive, Injen intake, FT86 Header, Motiv OP/DP, Nameless Axleback, 4.88 Weir gears, Subaru Legacy GT brakes, Five Axis spoiler, Shark Fin, 3000k HID's, LED goodies
KVDB31 is offline   Reply With Quote
Old 07-13-2013, 04:13 PM   #3
jybrd
jybrd's Avatar
What does install include? Ive done my own work thus far. How does the tunes work? Do i email them and tell them that I have this exhaust and that intake and they build around that?
edit: found it, seems easy enough. Maybe just a couple hours. My next question would be installing the Maps. What do you do?
Old 07-13-2013, 05:18 PM   #4
aagun
Drives: 86
WHY UniChip vs EcuTek
only ????
we should take all ecu flash *s , piggyback *s and EMS *s !!!
to make that fair
aagun is offline   Reply With Quote
Old 07-13-2013, 05:31 PM   #5
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Unichip looks pretty cool. Watched a video featuring their technology and r&d and tuning their 1500hp gallardo. Very impressive festures and capability.
For frs...what parameters can you tune? Extra features?
Also...dont forget brzedit. For 500 $ plus a openport2, you can tune your own car with access to all the factory tune parameters.
Toma is offline   Reply With Quote
Old 07-13-2013, 05:48 PM   #6
jybrd
jybrd's Avatar
only ????
to make that fair
Only reason it was between those two is because those are the ones I am considering.
The Following User Says Thank You to jybrd For This Useful Post:
sosick (08-27-2013)
Old 07-13-2013, 06:32 PM   #7
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
http://www.ft86club.com/forums/showt...ecutek+unichip
Literally the same post title...
KKaWing is offline   Reply With Quote
The Following 2 Users Say Thank You to KKaWing For This Useful Post:
ATL BRZ (07-15-2013), RehabJeff86 (07-13-2013)
Old 07-13-2013, 06:34 PM   #8
pgeist
pgeist's Avatar
Drives: 2013 Black BRZ Limited 6MT
I just installed my Unichip today and it was a breeze. Car just feels completely different now (in a good way!).
If you get in on one of the special buys it's a no brainer good deal.
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
Future: Catted header, OEM Audio+
pgeist is offline   Reply With Quote
Old 07-13-2013, 06:56 PM   #9
swift996
swift996's Avatar
I've run both. If you're just sticking to bolt-ons, unichip is a 95% solution for more than half the price.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
JPxM0Dz (07-15-2013)
Old 07-13-2013, 07:23 PM   #10
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Im going with ECUTek
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 07-13-2013, 07:35 PM   #11
Toma
Oooops. Dp
Old 07-13-2013, 07:35 PM   #12
Toma
This quote from Unichip Jack is intriguing.
Apples and Oranges
I wasn’t going to post because I think lOaded is spot on saying there’s a “unavoidable ownership bias…” it’s a lot like politics. That said, there are some simply wrong statements floating around the threads. The Unichip is at its heart custom tunable… has been for more than 15 years.
Clearly, EcuTek is well sorted, does some cool stuff, and lots of guys have a basic understanding of how it works. Unfortunately, that basic understanding doesn’t translate to a different product. A “head to head” comparison based on how many OEM tables the tuner has access to is meaningless because it’s not how Unichip works. Likewise, how the Unichip takes apart/manipulates/reintegrates an OEM signal is just as meaningless because it’s not how EcuTek works.
Does the FT86 Unichip kit manipulate the MAF to change fueling… yep. It’s clean, simple, and accomplishes what most guys want for their cars. Is that the only way Unichip can effect fueling… nope. Can you completely remove the MAF and convert the engine to speed-density… yep. Direct OEM injector control… yep. Integrate additional injectors… yep. Direct cam control… yep (has nothing to do with the MAF). Integrate a FI kit… yep. Modify tip in fueling… yep. Launch control… yep. Flat foot shifting… yep. Create a fully automatic 3D map directly controlling a nitrous solenoid while optimizing timing/fueling and automatically changing to non-nitrous values when the gas runs low… yep. Immobilize the car with a switch flip… yep. Integrate external sensors… MAP sensor… yep, flex fuel sensor… yep, closed loop waste gate solenoid, yep… additional injectors, yep… automatic 3D water spray with auto shut off and map switching… yep, etc…
Our basic kit is just that… a basic kit. It utilizes about 10% of the Unichip’s capability because that’s what 90% of the market wants… have fun with no foot print… not a footprint that’s just hard to find. How hard do you think the dealer will look at a car that cruises in with an engine problem?
If you are in the 10% and want to do more, give us a call or shoot me a pm and we’ll be happy to help.
The Following User Says Thank You to Toma For This Useful Post:
Mike86 (07-13-2013)
Old 07-13-2013, 08:22 PM   #13
Rombinhood@OpenFlash
Drives: FRS
Hi guys,
There will be a handheld flashing device coming out soon for your cars
Rombinhood@OpenFlash is offline   Reply With Quote
Old 07-13-2013, 08:29 PM   #14
nakamur21
Drives: 2013 BRZ limited
Care to elaborate?
nakamur21 is offline   Reply With Quote
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
Unichip vs ECUtek? l0aded Engine, Exhaust, Transmission 140 03-10-2014 07:34 PM
Unichip-SOLD Hops Normal Engine, Exhaust, Bolt-Ons 7 07-09-2013 10:30 PM
Ecutek vs unichip? Mustang88_357mag Engine, Exhaust, Transmission 15 05-14-2013 12:40 PM
EcuTek vs. Unichip? forzajuve Engine, Exhaust, Transmission 5 04-26-2013 12:09 PM
