| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2013 "AVO Orange" FR-S
AVO Silicone Inlet and Sound Tube DIY
1. Recommended tools on hand - A flathead and philips head screwdriver, and some pliers. Yes, you could probably do it without them if you are on the side of the road and desperate, but it's generally suggested to have at least these.
![]() 2. AVO wire-reinforced Silicone Inlet and Sound Tube. Definitely a necessity. ![]() Removal of the standard inlet and sound tube. 3. Removal: Loosen off the big clamp on the OEM hose at the Intake Box end. ![]() 4. Loosen off the big clamp on the OEM hose at the throttle body end. ![]() 5. Use the pliers to loosen the clamp on the small breather line hose. ![]() 6. Then move the clip up and off the inlet to help with removal, and use the flathead screwdriver to carefully pry out the fitting. ![]() 7. Loosen off the clamp at end of the sound tube. ![]() 8. Carefully pull the sound tubed off. ![]() 9. Now carefully pull the entire inlet and sound tube assembly out of the engine. ![]() 10. Use the pliers to loosen the big clamp holding the resonator box on the stock inlet, and remove that box. Make sure to remember the orientation of the box (towards the front of the car). ![]() Part 2: Installation Installation is a simple reverse of the removal process. It's helpful to keep some sort of lubricant on hand, such as plain old dish soap, to help get fittings into the silicone pieces. 1. Fit the resonator box to the AVO Silicone Inlet. Check alignment of the box to make sure it's not rubbing on the pulleys. ![]() 2. Fit the AVO Silicone Inlet pipe back in to the throttle body, breather line, and intake box. Keep the clamps loose while you get everything lined up. Then fit the AVO Sound Tube to the inlet pipe. There is a metal pipe insert to fit the two pieces together with. ![]() 3. Tighten everything up, and you are ready to go!
Drives: 13 fr-s whiteout
Where to buy?
![]() Color options and sound tube delete compatibility option pleaseeee
I'll be back!!
Drives: 16 Impreza 5dr CWP
Make it available in black and I'm sold.
Drives: nissan frontier, DGM MT BRZ
Does it come without the sound tube?
Drives: MKVI VW GTI
DADA
Drives: 2013
![]() ![]() ![]() All color available (and in stock), and they inlets of course will be available separate from the sound tubes (and vice versa). I'm getting the sound tube caps for the silicone inlets made now. |
Where do i send my money and how much of it??????
Up on the online shop - just warning, though, they won't ship till next Tuesday because of Labor Day.
http://www.avoturboworld.com/avoshop...-c-95_100.html |
#10 |
What are the gains from doing this other then looks?
#11 |
A little over 10% increase in air flow through the inlet, with a much larger area at the bend vs. stock to smooth flow through. Additionally it gets rid of the accordion section and smooths that out.
#12 |
Drives: MKVI VW GTI
I believe it was 10% greater flow than stock, and the fact that it's a smooth and consistent diameter (76mm) throughout, versus the crinkley oem hose.
Probably not much in the way hp gains doing it on its own, but when coupled with a panel filter (Which someone here proved was good for about 5whp), it'll probably make itself more known ![]() Edit: And I was too late in replying, but hey, at least I had the facts right XD |
#13 |
NW Region Moderator
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
#14 |
DADA
Drives: 2013
I know you got decent prices for the packages, but would you be willing to do a Group buy?
| Why delete the sound tube? | feldy | Engine, Exhaust, Transmission | 77 | 04-05-2021 11:12 PM |
| Sound tube mod? | smbrm | Engine, Exhaust, Transmission | 25 | 06-20-2012 07:24 PM |
| Sound induction tube - can it be modded? | ahausheer | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 06-05-2012 02:23 AM |
| The intake sound tube | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 12-09-2011 07:32 PM |
| Sound induction tube Yay, or ay? | ahausheer | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 12-04-2011 09:30 PM |
