The White Pearl
Drives: '13 Whiteout FR-S M/T
LED sizes Length, Width, Type
Hey guys,
I have found a lot of info on FR-S led's out there, and although a lot of vendors on here sell led kits they are usually rather expensive. If you go online you can find led's cheap, however I have some questions because the info doesn't seem to be out there. 1. What are the actual length and width sizes on the bulbs? I know the bulbs I.E the reverse lights, trunk lights, license lights and side markers are a mix of W5W, 194 and T10 bulbs, but whats the max size length and width you can put it without it being a problem. 2. Is there a problem with using Cree led's for more than the reverse lights, because I would prefer to use them everywhere if possible instead of the 5 smd 5050 leds you see everywhere online. 3. Does the volts or watts really matter for each different bulb and location in the car? or can they all be similar as long as it's a low number? Sorry for all of the questions but I just don't want to order a bunch of bulbs and they don't fit, or they end up causing problems. Thanks for any help! |
Custom User Title
Drives: Asphalt FR-S MT
3. There is a difference in consumed wattage between the various colors and sizes. Some colors operate at lower voltages while other require higher voltages. They all roughly run at the same current though. Depending on the number of individual emitters and whether you decide to run them in parallel or series, you need the right resistance at a given voltage.
Custom User Title
I kind of got cut off.
1. Go measure the holes with calipers, a ruler, or even drill bits or something. 2. Crees typically run a bit hotter, but provided there is space, I don't see how it would be an issue.
#4 | |
Checkout our online store. We have categorized our FR-S lighting and have confirmed fitment for our products so it would be a plug-and-play, easy installation and no modifications are required. Also have options depending on your preference for LED brightness.
www.hidpowerhouse.com Quote:
Custom User Title
I don't think this is the right thread to advertise in.
Sent from my mind using telepathy.
CREE style LEDs can be used for more than just reverse lights. We sell them for turn signals, fog lights etc..
They don't have the same output as HID's, but they are brighter than most SMD style bulbs and have a really clean look IMO. If you guys have any questions about LEDs or HIDs feel free to shoot me a PM. Thanks! Nick C.
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | RealShkillz (07-05-2013) |
#7 | |
Drives: 2008 Honda Civic Si
Keep in mind that just because there are 100-SMD LED chips on the bulb, it's going to be as bright as the sun. LED brightness depends on the type of chip being used; i.e. three 1210 LED chips is equivalent to about one 5050 style LED chip, etc. Sometimes less is more, it all depends on the bulb and who you get it from. 2. You can use CREE LED bulbs for other parts of the car, but make sure you research the bulb you're getting. CREE LED bulbs are indeed bright, but brighter LED chips tend to create more heat and heat dissipation is critical to the life of an LED bulb. 3. 12v is a requirement for all or most aftermarket LED bulbs. Your car uses different wattage incandescent bulbs depending on how bright it needs to be, but with LED's, the wattage produced is much less and shouldn't be the determining factor in the purchase. LED brightness is measured in lumens and that should be your deciding factor in which one to buy, more lumens = brighter. I would recommend contacting the people you are interested in buying from and they should be able to give you a more definite answer as every retailer has different products. :happy0180: |
| The Following User Says Thank You to iJDMTOY For This Useful Post: | RealShkillz (07-05-2013) |
| Tire Width? | wootwoot | Tracking / Autocross / HPDE / Drifting | 84 | 03-06-2019 07:44 AM |
| ?equal length or unequal length headers? | subaruferrucci | Engine, Exhaust, Transmission | 22 | 07-11-2013 12:56 AM |
| Track width | -max- | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-21-2012 06:37 PM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
