Old 07-02-2013, 11:06 PM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
brake pedal doesn't return smoothly
Recently i've noticed that my brake pedal doesn't return all the way smoothly. If i depress the brake pedal hard, it'll return normally most of the way, but the remaining feels like it got stuck on gum or something, stick for a bit and returns. I checked my brake fluid it's fine. Is it a concern? Is it something that i can check myself?
chenshuo is offline   Reply With Quote
Old 07-10-2013, 09:22 AM   #2
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
no one?
Old 07-10-2013, 09:29 AM   #3
Mikem53
Drives: FR-S 6MT
Did you look at the pedals and linkage to make sure nothing is obstructing or binding? Not sure there is much else to check.. Other than the master cyl.. Does it brake fine... Not spongy?
Mikem53 is offline   Reply With Quote
Old 07-10-2013, 09:54 AM   #4
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
Also check after a drive and make sure your rotors aren't super hot, it could be that one of your calipers is sticking. This happened to my brother with his mustang, he just had to replace a small part. I don't recall what it was, but I remember it was a cheap fix.
Surakusa is offline   Reply With Quote
Old 07-10-2013, 12:14 PM   #5
strat61caster
strat61caster's Avatar
I started messing with it and I feel it too. It's probably just roughness in whatever return mechanism is used (spring, vacuum I'm not well versed on modern brake systems) and really only happens after you're on the last ~5% of travel.
I'm not going to worry about it, I'm just going to remove my foot from the brake smoothly and quickly like usual, you don't feel it if you're just driving, you have to play with it to find it.
ineedyourdiddly
Old 07-10-2013, 02:01 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm pretty sure its vacuum not exactly sure but I would check a service manual out.
Old 08-14-2013, 06:06 PM   #7
Ekimmel86
Drives: Whiteout FR-S
My Brake pedal got stuck down causing the car to skid out of control. I am waiting for Scion to get back to me.
Ekimmel86 is offline   Reply With Quote
Rock Hard Brake pedal in the middle of an autocross run... Jedi1 Tracking / Autocross / HPDE / Drifting 67 05-22-2018 03:40 PM
Help! Oil filter isn't coming off smoothly ShoGun Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 11-26-2015 08:58 AM
(6MT) Getting into 2nd smoothly l0aded Scion FR-S / Toyota 86 GT86 General Forum 16 04-19-2013 05:10 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Odd brake pedal feel, fade? yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-11-2012 12:29 PM
