Old 01-17-2013, 01:24 AM   #1
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
Rock Hard Brake pedal in the middle of an autocross run...
Has anyone else gone for the brakes and gotten nothing but a rock hard pedal and almost zero slow down?
I had a Mk4 R32 VW that would do this if you barely got into the ABS and then tried to modulate the brakes to balance the car. If you barely touched the ABS while while working the brake pedal it would go hard as a rock and do nothing to slow the car.
Had this happen at a test and tune autocross a month or so ago in the FRS. It has only happened one time and I just can't remember the circustances leading up to the incident. Just curious if anyone else has experienced this and if they know the exact cause.
Thanks for any info you can provide.
Jedi1 is offline   Reply With Quote
Old 01-17-2013, 01:50 AM   #2
Do this: http://www.ft86club.com/forums/showthread.php?t=25494
Old 01-17-2013, 02:01 AM   #3
Jedi1
Jedi1's Avatar
I was wondering if that would cure the problem. I will be trying it the next time I'm at an autocross or on track. Does that kill the ABS though?
Thanks for explaining your experience with and without the "Pedal Dance". I will be trying it out!
Old 01-17-2013, 02:08 AM   #4
ABS will still be there.
Old 01-17-2013, 02:14 AM   #5
whataboutbob
AutoX-10/10ths every run
Yes. I'm gonna try to do the "pedal dance" as noted in the linked thread.
Build thread:Here
Old 01-18-2013, 09:29 AM   #6
d1ck
Drives: Black 2013 FRS
Sounds like "Ice Mode". It's happened to me before and I don't know if it's a fault with the design of ABS systems or an actual mode which is programmed. Pull the ABS fuse if you're afraid it will happen again.
d1ck is offline   Reply With Quote
Old 01-18-2013, 09:46 AM   #7
xwd
Unfortunately in the classes we run in you can't pull the fuse.
I'm not sure the pedal dance will defeat this or not but maybe it will if the function is built into the brake force distribution system...
I used to have a good spot with some broken up pavement I could get the ice mode to kick in 100% of the time on my WRX. I have yet to encounter ice mode with the BRZ with or without the pedal dance.
Old 01-18-2013, 02:11 PM   #8
Jedi1
Jedi1's Avatar
I have not heard or seen anyone else taking about it in regards to the FRS/BRZ. Figured I would throw this out there so folks would be aware it is possible in these cars and hopefully get some advice to keep it from happening in the middle of a National Event Winning Run! Dream big or don't dream at all! Lol. Thabks for the advice given regarding the issue. Can't wait to try it out.
Old 01-18-2013, 08:40 PM   #9
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I did the pedal dance today but I wasn't in my car. Should I consult someone?
PRO86 | STL | LuckyDog
Old 01-20-2013, 04:51 AM   #10
Getagrip
Getagrip's Avatar
Drives: SWP BRZ
I had this happen to me more than once last season.
I will be doing the "pedal dance" from now on.
SWP BRZ
Getagrip is offline   Reply With Quote
Old 01-20-2013, 09:27 AM   #11
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I posted about it a couple times already, it happens to me Alot. It seems more if there is a bump before the turn, or a quick change in direction before braking. DO NOT remove the abs fuse, I tried it and all it does is lock up instantly. The pedal dance does not work in my at least, I tried it a couple times and it never activaties. I left foot brake, I think that makes it happen easier. This season, I am going to try to Not left foot brake to see what happens. It is Very scary when it happens, I am always looking for corner workers and light poles hoping I can stop in time. I found the best way to deal with it is, when it happens let off the brake and start your turn it seems to work every time.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 01-20-2013, 10:11 AM   #12
IMOA
Drives: 86 GTS
If it's the same problem that jedi1 also experienced in his MkIV R32 it's in the software of the abs unit so it's quite unlikely that pedal dance will help. There was quite a bit of investigation in Australia around this problem in the Golfs about 8 years ago and my understanding is that it the problem occurred when getting a wheel in the air under heavy braking (but not every time when a wheel was in the air). Is this happening to people only during autocrosses (maybe slower speeds and bigger direction changes which lead to wheels being picked up?) or has it happened to people on a racetrack as well?
IMOA is offline   Reply With Quote
Old 01-20-2013, 11:54 AM   #13
Jedi1
Jedi1's Avatar
I have never experienced it on the street and only twice on a proper race circuit. It gets fairly exciting in the car when you are at the point of turn in and there's a bit of trail braking to do at the limit. Boom! NO brakes when you need them the most! Not Cool!
Old 01-20-2013, 01:23 PM   #14
xwd
Simmons
One thing to keep in mind with the "pedal dance" is the car has to be completely warmed up, and I would guess it is based off the coolant temp. If it's not warmed up completely it won't work. I practiced a couple times after getting to/from work and it never failed. I can do it faster than holding the button down for 3 seconds.
Whether it works for this or not, I kind of doubt it myself but others have mentioned it helped a lot with trail braking at least on road courses.
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Rattle from the middle of the car brichard0625 Issues | Warranty | Recalls / TSB 11 10-05-2012 07:04 PM
Odd brake pedal feel, fade? yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-11-2012 12:29 PM
First Whiteout 86 in the Middle East i_giado Member's Car Journals 26 07-09-2012 05:30 AM
Anybody near Middle Indiana AX_FRS Tracking / Autocross / HPDE / Drifting 17 06-01-2012 11:16 PM
