Location of the secondary amp
Hi Folks,
I'm new to this forum and my FR-S. Yes, I've tried a search....... ![]() I understand that the standard radio in the FR-S, has an additional amp (other than what is in the head unit). Is this what I'm looking at in the picture? I recently had the head unit replaced (with a Kenwood DNX570HD) and asked the installer to make sure that amp in the trunk was hooked into the system. How can I check to make sure it's hooked in? Should the cover be warm if it's active? TIA humfrz |
Drives: 86 GT Manual - Sonic Blue
That's the amp. If you get sound through the door speakers, it's hooked up.
Drives: BRZ DGM Limited
Is there anyway to add a sub directly to the stock amp? Not looking for huge thump, just to round out the low end sound.
#6 | |
head of infinite swagger
Drives: 2013 FR-S 6MT
If you ran another power wire then you might as well run real RCA cables from the deck and hook it all up properly. Check out this thread for more info on the stock amp wiring: http://www.ft86club.com/forums/showthread.php?t=42239
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
Shorter of breath
Drives: a soft bargain
12AWG is good for 25A, in 60C-rated wire. That's enough to support at least a 150W Class AB amp.
It's not going to knock down buildings, but I suspect for most people it's more than enough. |
| FS: OEM downpipe / Secondary catalytic converter | cb7tuner | Engine, Exhaust, Bolt-Ons | 2 | 06-07-2016 01:17 PM |
| Secondary O2 sensor needed for Cruise control? | DJCarbine | Engine, Exhaust, Transmission | 31 | 04-10-2015 08:49 PM |
| Secondary Fuse Block for Interior Circuits | F1point4 | Electronics | Audio | NAV | Infotainment | 1 | 06-17-2013 12:09 AM |
| Secondary cat removal | wootwoot | Engine, Exhaust, Transmission | 7 | 05-29-2013 11:42 AM |
| Secondary Cat | sw20kosh | Engine, Exhaust, Transmission | 2 | 03-11-2013 02:41 PM |
