Old 06-16-2013, 08:30 PM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Secondary Fuse Block for Interior Circuits
Wanted to share out of my journal. Enjoy
http://www.ft86club.com/forums/showp...&postcount=243
Originally Posted by F1point4 View Post
Tuning!
Well...tuning of the wiring inside my cabin. Since I purchased Lola I have added a few gadgets to the inside. Traditionally I've been a fan of using add-a-circuits to the stock fuse box, but it is getting crowded and adding a gauge to the car would make things messier.
I decided to get a fuse block and clean up all my wiring because I believe in clean. Haha. It'll also make wiring the gauge a lot easier since I don't have to add a 5th add-a-circuit to my fusebox and add a 5th wire to the ground screw. Removing add a circuits also prevents my accessories from messing with the circuits i'm tapping into.
I have four accessories I planned on wiring up
Dashcam, Radar, AVO Throttle Controller, AEM Gauge
This is no DIY, just pure information. Please note there are a lot of ways to achieve what I did.
Let's go
The foundation of my system. BlueSea Systems 5025 Fuse Block.
The cover to the box can hold two spare fuses. A 15 amp fuse comes with it. The only thing I don't like is that the box is kinda big, and it uses the big ATO(?) fuses. I'd like if it was consistent but can't win them all. I also couldn't find a good fuse block on amazon so I kinda settled on this one.
http://www.bluesea.com/products/5025..._Bus_and_Cover
20130614-ProjectCleanupElectricals-017 by VictorN07, on Flickr
Cover off. It can support six circuits. Has a ground and positive bus. Supports 30A per circuit. I could add one of these under the hood for my lighting circuits
20130614-ProjectCleanupElectricals-022 by VictorN07, on Flickr
Before pictures
20130614-ProjectCleanupElectricals-028 by VictorN07, on Flickr
That connector on that white L plastic bracket has to move. Easy enough to unclip from the bottom.
20130614-ProjectCleanupElectricals-029 by VictorN07, on Flickr
It moves to make room for my mounting circuit. I chose this area because
1) I didn't find a good spot on the passenger side
2) I didn't want to run a wire directly to my battery. I didn't need that kind of amperage. The accessories that I was hooking up to the block are switched by ignition so I didn't need an always hot connection to the battery
3) This was close to the stock fuses, so I can tap into it for power for the block
4) I wouldn't have to run a ton of new wiring, or move all my accessory wires
20130614-ProjectCleanupElectricals-032 by VictorN07, on Flickr
Cluster of wires
20130614-ProjectCleanupElectricals-034 by VictorN07, on Flickr
Fuse box cover off. You can see I have four add-a-circuits here. Getting busy under there
20130614-ProjectCleanupElectricals-039 by VictorN07, on Flickr
20130614-ProjectCleanupElectricals-050 by VictorN07, on Flickr
I digress
People have asked me how I mounted the hardwire for the radar. Here are two pictures. Not the cleanest, but it can't be seen and it works
20130614-ProjectCleanupElectricals-055 by VictorN07, on Flickr
20130614-ProjectCleanupElectricals-060 by VictorN07, on Flickr
Going to work
Ground wire
20130614-ProjectCleanupElectricals-071 by VictorN07, on Flickr
Positive wire - It will tap into the fusebox on a non system critical circuit - cigarette power plug. I just put moderate sized fuse in it. 10A. Plenty to support what I will be using it for
20130614-ProjectCleanupElectricals-073 by VictorN07, on Flickr
Coming together
20130614-ProjectCleanupElectricals-077 by VictorN07, on Flickr
Before of all my accessory wires.
20130614-ProjectCleanupElectricals-065 by VictorN07, on Flickr
The after. I wrapped everything and shortened some wires.
20130614-ProjectCleanupElectricals-081 by VictorN07, on Flickr
Danbo showing off
20130614-ProjectCleanupElectricals-083 by VictorN07, on Flickr
Labeled cover
20130616-ProjectElectricalWrapup-001 by VictorN07, on Flickr
Much better. The fuse block is taped on with 3M Red double sided tape
20130616-ProjectElectricalWrapup-005 by VictorN07, on Flickr
I'm not totally finished with adding the gauge so I don't have final pictures of what everything looks like. What is there so far looks very very clean.
Hope this gives people some ideas on keeping stuff neat under there.
F1point4 is offline   Reply With Quote
Old 06-17-2013, 12:09 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
I'd been wondering how to do this cleanly. thanks for the post. gave me some ideas.
FS: OEM downpipe / Secondary catalytic converter cb7tuner Engine, Exhaust, Bolt-Ons 2 06-07-2016 01:17 PM
Secondary O2 sensor needed for Cruise control? DJCarbine Engine, Exhaust, Transmission 31 04-10-2015 08:49 PM
Secondary cat removal wootwoot Engine, Exhaust, Transmission 7 05-29-2013 11:42 AM
Fuse Block Question zanmor Electronics | Audio | NAV | Infotainment 2 04-06-2013 01:58 PM
Secondary Cat sw20kosh Engine, Exhaust, Transmission 2 03-11-2013 02:41 PM
