Old 06-23-2013, 01:40 AM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
3-bar map sensor wiring
Anyone have an upgraded map sensor, and can tell me the stock wiring scheme? MY new sensor is 3-wire, and the factory has more than that.
Any help, links, etc...
Thanks
gdrider77 is offline   Reply With Quote
Old 06-23-2013, 11:03 AM   #2
mad_sb
Drives: 2013 Asphalt FR-S
this may help, compiled from the service manual pdf that is available on this site.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
Sportsguy83 (06-23-2013), xkalelx (09-01-2015)
Old 06-23-2013, 12:05 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks
Sell it like hot cakes. Get a plug and play map sensor.
06+ S2000.
Old 06-23-2013, 12:19 PM   #4
gdrider77
gdrider77's Avatar
Its the omnipower ....MAP-K-3BAR
Old 06-23-2013, 12:25 PM   #5
Sportsguy83
Drives: Limited BRZ
This is the sensor that Paul sent me with my AVO kit. Wonder why they recommend this when there is a plug and play option?
I think you are trying to plug it into the MAF sensor instead of the MAP. Are you tring to plug it in in front of the A/C compressor? The MAP sensor sits below the engine cover that says (Subaru Toyota DS4). I bet thats it!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
King Tut (06-24-2013)
Old 06-23-2013, 12:28 PM   #6
gdrider77
gdrider77's Avatar
ugh....
That what happens when you work all night...
hahah, man im a friggin idiot...Been working on this like since 5pm ylesterday. Maybe i need a break.
Got to say though, i took it for a quick test run to check for leaks around 3am...man, even with a base tune at like 5psi, what a huge difference....note to self. SEcure fender plastic better if doing that. The wind blew those right into the tires at hi speeds and melted some of the plastic fender liner stuff...hahah
David, as always, thanks for the help man, you have been a huge asset!
Yes everyone....im an idiot
Old 06-23-2013, 12:32 PM   #7
Sportsguy83
Drives: Limited BRZ
ugh....
LOLOL! You are not an idiot.. You are not the first one this has happened to... (wink wink)
You're welcome!!
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
King Tut (06-24-2013), wparsons (06-23-2013)
Old 06-24-2013, 03:06 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I had to ask David why my car wouldn't run after I installed my OmniPower 4 BAR MAP sensor.
The Following User Says Thank You to King Tut For This Useful Post:
Sportsguy83 (06-24-2013)
Old 07-07-2013, 12:35 PM   #9
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
You're welcome!!
Face Palm I did the same thing :-(
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
The Following User Says Thank You to pheoxs For This Useful Post:
Sportsguy83 (07-07-2013)
Old 11-22-2013, 02:46 PM   #10
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
stupid question as @gdrider77 is apparently using it...MAP-K-3 BAR from omnipower works for the FRS right? I dont plan on going 40+ psi ever so Im about to buy 3 bar for the RSX??
Pablitomarrero is offline   Reply With Quote
Old 11-22-2013, 02:50 PM   #11
gdrider77
gdrider77's Avatar
Yeah works fine...
This is what i am using.
http://www.rallysportdirect.com/Omni...Bar-MAP-Sensor
Do note, you will need a retune for it though.
The Following 3 Users Say Thank You to gdrider77 For This Useful Post:
Draco_PR23 (11-22-2013), Pablitomarrero (11-22-2013), Sportsguy83 (11-22-2013)
Old 11-22-2013, 02:53 PM   #12
Pablitomarrero
Yeah works fine...
Yeah ill be tuning the turbo with this. Thank you!
Old 11-22-2013, 03:08 PM   #13
jamesm
you don't really need a tune for changing a map sensor... just need to scale it properly in the map. anyone who can click a mouse can do it. ecuflash/romraider or openflash/tunerpro can both do it (though the values need to be converted depending which software you use).
The Following User Says Thank You to jamesm For This Useful Post:
Pablitomarrero (11-23-2013)
Old 11-23-2013, 12:56 AM   #14
gdrider77
gdrider77's Avatar
Yeah, i guess that is true...when i said tune, i kind of meant that, basically you need to tell the ecu that it is now using a 3bar map sensor.
The Following User Says Thank You to gdrider77 For This Useful Post:
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Map Sensor Hookup? ft86-UAE Forced Induction 22 01-08-2015 03:56 PM
02 Sensor mjsivee Engine, Exhaust, Transmission 4 06-13-2013 01:58 PM
Bad MAF Sensor paulieblaze Scion FR-S / Toyota 86 GT86 General Forum 3 08-23-2012 10:34 PM
Stock O2 Sensor d1ck Engine, Exhaust, Transmission 1 07-11-2012 07:16 AM
