Drives: Scion Fr-s
30mm spacer in the rear?
Has anyone put 30mm spacers in the rear with stock wheels with a eibach sportline drop? If so any rubbing?
Drives: B8 A5
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I had 30mm spacers in the rear, stock wheels, but with pro-kit (not sportline). Some slight rubbing with the fender when I hit a big dip on the freeway. I suspect with the added 0.4" drop of the sportline and the wheels being sucked in a bit more, the rub wouldn't be as bad or won't really happen.
| Wheel Directory: Enkei PF01 17x8.0 +45 | NickFRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 07-30-2019 08:39 AM |
| How much spacer is safe on stock rear studs? | wparsons | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 12-27-2014 01:49 AM |
| 25mm conversion spacer with 5mm spacer = safe or unsafe? | deedz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-05-2013 11:59 AM |
| WORK Emotion Kiwami - Aggressive Concave - 18x9.5 +30mm // All Color In Stock | RavSpec | Wheels and Tires | 11 | 10-03-2012 11:05 AM |
| Dealer Option 30mm Drop Lowering Springs | switchlanez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 09-12-2012 04:50 PM |
