Old 06-19-2013, 02:09 AM   #1
Bskeeter1
Bskeeter1's Avatar
Drives: Scion Fr-s
30mm spacer in the rear?
Has anyone put 30mm spacers in the rear with stock wheels with a eibach sportline drop? If so any rubbing?
Bskeeter1 is offline   Reply With Quote
Old 08-05-2013, 11:25 AM   #2
stefmiesterb
stefmiesterb's Avatar
Drives: B8 A5
did you ever find out?
stefmiesterb is offline   Reply With Quote
Old 04-13-2014, 01:10 PM   #3
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I had 30mm spacers in the rear, stock wheels, but with pro-kit (not sportline). Some slight rubbing with the fender when I hit a big dip on the freeway. I suspect with the added 0.4" drop of the sportline and the wheels being sucked in a bit more, the rub wouldn't be as bad or won't really happen.
mit_peid is offline   Reply With Quote
Wheel Directory: Enkei PF01 17x8.0 +45 NickFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-30-2019 08:39 AM
How much spacer is safe on stock rear studs? wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 12-27-2014 01:49 AM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
WORK Emotion Kiwami - Aggressive Concave - 18x9.5 +30mm // All Color In Stock RavSpec Wheels and Tires 11 10-03-2012 11:05 AM
Dealer Option 30mm Drop Lowering Springs switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-12-2012 04:50 PM
