Old 06-15-2013, 03:34 PM   #1
lxsedan
Drives: 2013 BRZ SWP
guys who are running Catless front pipe
Hey guys that are running catless front pipes, Invidia, Motiv etc.. are you guys having problems with smoke and smell coming from the exhaust? Or does the first cat fix it all.
Wanting to do the front pipe but do not want smoke and fumes going catless on the front pipe.
lxsedan is offline   Reply With Quote
Old 06-15-2013, 04:13 PM   #2
hunter3232792
hunter3232792's Avatar
Drives: FRS
j2 works fine for me no problems
hunter3232792 is offline   Reply With Quote
Old 06-15-2013, 04:49 PM   #3
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
I'm getting no smoke at all with a fully catless engine back, when I had just the catless front pipe there was no fumes or smoke as well, the strong fumes come once you take out the headers.
Build Thread
Instagram
Old 06-15-2013, 04:57 PM   #4
Mike86
Drives: Scion frs
Imvidia catless front pipe no smell or smoke
Mike86 is offline   Reply With Quote
Old 06-15-2013, 07:38 PM   #5
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I only had smell and smoke when burning in my exhaust's resonator. no smell or smoke. the secondary cat is quite small.
Old 06-15-2013, 11:34 PM   #6
20firestorm13
Drives: 2017 Halo Toyota 86
Did you change everything at once? It's not uncommon for a smell to occur for a few days as your new system burns off impurities that are on it after it is hooked up. If you smell fuel/gas exhaust that can come from exhaust leak or you could be running rich. I would suggest a tune, that helps a ton as well.
20firestorm13 is offline   Reply With Quote
Old 06-15-2013, 11:54 PM   #7
lxsedan
I only did the cat back but I wanna do the front pipe as well. I been hearing stories of other guys who did the catless front pipe smoking and smelling but on different cars.
I guess the question now is stick with Invidia to go with the Q300 or go Motiv
Old 06-16-2013, 08:38 AM   #8
wparsons
wparsons's Avatar
Any new exhaust part can (and likely will) smoke and smell a bit for the first few days as coatings and impurities burn off, but in the long run they'll be fine. If you run fully catless it will definitely smell different in the long run.
flickr
Old 06-16-2013, 08:54 AM   #9
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Before I put the header on I had a P&L overpipe, catless frontpipe and an SRT catback.
I only smelled a little fumage when I started it in the garage. Not bad, but expected.
Once I had a header with a high flow cat installed, the fumes seemed a bit stronger but to me, it's all relative.
I grew up around cars with no cats, and less efficient ones. I actually enjoy the smells. As long as I'm not couped up in an enclosed space, it ain't nothin' but a thang...
CircuitJerk is offline   Reply With Quote
Old 06-16-2013, 11:52 PM   #10
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
Stock header with ark front pipe. No smells at all other than just exhaust.
My last car had a catless header, but catted front pipe and that reeked.
Propaganda is offline   Reply With Quote
Any NY'ers install catless front pipe? ShoNUFF NY / NJ / CT / PA 19 01-04-2015 08:30 PM
Anyone only running a catless front pipe?? Pele86 Engine, Exhaust, Bolt-Ons 7 08-01-2013 02:35 PM
WTB Any Catless Front Pipe ramiram1984 Engine, Exhaust, Bolt-Ons 0 06-10-2013 06:45 PM
Invidia Catless front pipe NEW Area51 Engine, Exhaust, Bolt-Ons 1 05-21-2013 01:54 AM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 01:10 AM
