Old 06-15-2013, 02:18 PM   #1
4pokguy
Drives: 2013 BRZ WRB Sport Tech MT
Injen Intake, install before or after engine break-in?
Got my intake.... getting the car next week. I was wondering if it makes a difference if I install the intake right away, or if it's better to wait until after the engine has been broken-in. Can anybody chime in on this?
Thanks!
4pokguy is offline   Reply With Quote
Old 06-15-2013, 02:26 PM   #2
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Why not try out the car with the stock for a while and then change it? haha i love mine it sounded awsome. But not sure about if you should wait till break in first haha
Minovsky is offline   Reply With Quote
Old 06-15-2013, 02:41 PM   #3
jflogerzi
jflogerzi's Avatar
Search. This question has been asked before. But no need to wait. You can do it whenever.
Old 06-15-2013, 02:44 PM   #4
4pokguy
I did a search, but way too many posts to go through.... I've test driven the car in stock already... need more power, so i'm gonna slap it on as soon as i get it back to my garage. Thanks for the answer guys!
Old 06-16-2013, 03:41 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
You'll find at break in RPM that the Injen will probably make the car perform worse.....
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-16-2013, 08:23 AM   #6
BRZnut
Drives: BRZ DGM Limited
To be honest, with all the engine issues these cars are having, I wouldn't do any modifications of the engine until after the warrentte is over, not just the break in period. Last thing you want is the dealer to see the intake and use it as an excuse to not cover an engine problem. (if this engine had been out for years with no problems, then it would be less of an issue. But this is not the case here..one issue after another , and now early DI failures)
Old 06-16-2013, 08:33 AM   #7
wparsons
wparsons's Avatar
The biggest reason I would suggest waiting is because an intake won't increase low end power at all, and might actually lose some power down low, and you don't want to be redlining it during the break in period.
Out of curiosity, how high did you rev it on the test drive? All the power is above 4500rpm, so if you were below that you're missing out anyway. As an FYI, an intake alone is not going to make enough more hp to feel it on the road so you might be better off just saving your money until you're prepared to spend more all at once (intake, header back exhaust and tune will be noticeable)
flickr
Old 06-16-2013, 01:31 PM   #8
Lonewolf
Lonewolf's Avatar
Drives: Moped
I would wait until after break in for two reasons:
1) Many members have experienced bogging/idling issues with the Injen intake.
2) There are still several little "hiccups" being worked out with this motor and factory tune, and you should break the car in and be a little hard on it first to see how the car is behaving before altering it further.
JRP's Injen intake/Exhaust install in part #2 Stav Engine, Exhaust, Transmission 2 10-18-2012 12:57 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
Proper Way to Break-in New Engine c0rbin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 32 07-03-2012 09:12 AM
How did you break in your engine? WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 4 06-05-2012 01:12 AM
Engine break in period - how necessary is this? WhippleDip Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 05-16-2012 03:38 PM
