Old 06-24-2012, 11:35 PM   #1
c0rbin
Drives: 97' 240SX
Proper Way to Break-in New Engine
I've done a lot of research on this and the best way to break-in a new engine is basically to drive it hard. I don't have the time to explain this but I encourage everybody who just bought an FR-S to do some research on the best break-in procedure. If you are babying your car you end up with slightly less power and an engine that won't last as long. Here is a good starting point: http://www.mototuneusa.com/break_in_secrets.htm
c0rbin is offline   Reply With Quote
Old 06-24-2012, 11:40 PM   #2
csaba
Drives: scion tc
Thanks a lot !
Where did you get this from?
csaba is offline   Reply With Quote
Old 06-24-2012, 11:40 PM   #3
Linseal
Linseal's Avatar
Drives: Argento MT Scion FR-S
Oooooooor, do what it says in the manual and keep it under 4000 rpm for the first 1000 miles. I'm pretty sure Toyota and Subaru know something about the engine they built.
Linseal is offline   Reply With Quote
Old 06-24-2012, 11:45 PM   #4
csaba
Drives: scion tc
Delete thread!
Old 06-24-2012, 11:46 PM   #5
ahausheer
Re-member
Drives: Toyota camry
FYI: The FR-S is not a 10 year old freshly rebuilt motorcycle engine. Apparently the FR-S is a CAR with an engine that is vastly different than a motorcycle engine. Also, when you get this car it will have at least 10 miles on it and the engine will have been tested at the factory. Your website is an awful starting point, it is for motorcycle engines with zero miles on them, and is full of hearsay. There is nothing scientific about it. Plenty of other bona fide sources, like, oh I dont know, Toyota and Subaru recommend the opposite. There are already at least two long and hotly debated threads on this on this forum. If you have actual data or research papers those might help, also try the search button. Sorry to be so critical but you should not trust everything you read simply because it is well written and convincing.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-24-2012, 11:46 PM   #6
c0rbin
Drives: 97' 240SX
My guess is the reason the manual recommends a soft break-in procedure is because they don't want to make it company policy to be recommending that people hot-rod the car... also, a proper hard break-in is very specific and riskier than normal break-in if not done properly, and people can't be trusted to do it properly.
Old 06-24-2012, 11:48 PM   #7
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
@Dave-ROR I SUMMON THEE!!!!!
Exhaust is offline   Reply With Quote
Old 06-24-2012, 11:50 PM   #8
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
This topic has been beat to death already.
http://www.ft86club.com/forums/showthread.php?t=5618
Chewie4299 is offline   Reply With Quote
Old 06-24-2012, 11:54 PM   #9
TPO
TPO's Avatar
Drives: Scion fr-s,Lexus is250,4-runner
c0rbin, I went with your method back when I was a teen. My Dad kicked my A** when I spun a bearing in my civic si hatch. Think I will stick to the manual.
TPO is offline   Reply With Quote
Old 06-25-2012, 10:01 AM   #10
FRiSson
Drives: FR-S MT
Excellent!
FRiSson is offline   Reply With Quote
Old 06-25-2012, 11:20 AM   #11
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I've had over 20 new cars and I have always been gentle with them for the first 1000-1200 miles and have NEVER had any mechanical problems. I also changed the oil every 3000-3500 miles.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 06-25-2012, 12:09 PM   #12
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
There's already a break-in thread. And it's stickied.
But to add to this thread: It comes to what you want from the engine.
To get the peak HP sooner at the expense of engine longevity, follow the aggressive method above.
To get the most reliability and build up to peak HP later, follow the manual.
Old 06-25-2012, 01:02 PM   #13
c0rbin
Drives: 97' 240SX
^ No, you just made that up. The same thing that gives you more power makes it last longer.
Old 06-25-2012, 01:39 PM   #14
Draco-REX
Corner Junkie
Draco-REX's Avatar
This is why break-in threads suck so much.
rev the engine to 5000 rpm before break in period midnitz Scion FR-S / Toyota 86 GT86 General Forum 48 11-03-2013 10:24 AM
How did you break in your engine? WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 4 06-05-2012 01:12 AM
dealership 4 hours away, bad for engine break in? Mykflo BRZ First-Gen (2012+) — General Topics 27 05-23-2012 07:57 PM
Engine break in period - how necessary is this? WhippleDip Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 05-16-2012 03:38 PM
A proper test of the FR-S Vanguard Scion FR-S / Toyota 86 GT86 General Forum 2 03-19-2012 10:58 PM
