Old 06-14-2013, 12:05 PM   #1
trinitron
Drives: gts 86
More mechanical sound for AT manual mode?
Is there anyway or any aftermarket part that would give the AT 86's gear stick in manual mode a more mechanical or louder click when shifting up and down ? (Talking about in M mode, shifting up and down + - with the gear knob.)
trinitron is offline   Reply With Quote
Old 06-14-2013, 12:24 PM   #2
Tromatic
What it really needs is a neutral lockout. Did that once thinking I had it in manual. Lucky it was at idle.
Tromatic is offline   Reply With Quote
The Following 2 Users Say Thank You to Tromatic For This Useful Post:
AZOOZ_95 (06-14-2013), eddieEndo (06-16-2013)
Old 06-14-2013, 12:48 PM   #3
CaptainSlow
CaptainSlow's Avatar
No. AT doesn't work like that.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 06-14-2013, 12:53 PM   #4
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Its got reverse lockout, you need to be able to go into nuetural in case you spin the car so it doesnt stall out when the back end goes in the opposite direction
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-14-2013, 01:41 PM   #5
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
You could make some MP3's from some good movie shifting scenes and put them on a USB stick. Be sure to put about a 1 second delay in front of the actual sound effect.
Hit play on the audio file, then quickly "shift". Stand back and be proud that you are cool.
SloS14 is offline   Reply With Quote
The Following User Says Thank You to SloS14 For This Useful Post:
nbafandan (06-14-2013)
Old 06-14-2013, 02:09 PM   #6
GNS
Drives: .
Yes. It's called a 6 speed manual. You can find these on any FR-S.
GNS is offline   Reply With Quote
The Following User Says Thank You to GNS For This Useful Post:
GTB/ZR-1 (06-14-2013)
Old 06-14-2013, 02:11 PM   #7
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
Not the automatic ones.
Ryuu0u is offline   Reply With Quote
Old 06-14-2013, 08:35 PM   #8
trinitron
Drives: gts 86
Yep, keep being pretentious mate
Old 06-14-2013, 08:45 PM   #9
Tromatic
A sharp detent would fit the bill. I agree with the OP, I think, although the AT shift probably has more "feel" than the manual as is.
The Following User Says Thank You to Tromatic For This Useful Post:
trinitron (06-14-2013)
Old 06-14-2013, 08:52 PM   #10
Tromatic
Then I have more to learn. I grew up on MT cars. For some reason, it sees like instant death to shift an AT in to neutral or from neutral into gear, regardless of RPM. Thinking about it, I'd bet the trans software/hardware would a better job than a manual, even if it's slower.
A Week of A/T Manual Shifting Mode Ocala FR-S Scion FR-S / Toyota 86 GT86 General Forum 98 05-15-2013 02:35 AM
More MPG in manual mode (AT) aceangel BRZ First-Gen (2012+) — General Topics 11 03-27-2013 01:12 PM
AT - Failed to downshift in manual mode abutterman Issues | Warranty | Recalls / TSB 26 03-14-2013 09:11 AM
AT Manual Mode Easter Egg? whataboutbob Engine, Exhaust, Transmission 2 12-14-2012 11:03 AM
AT Manual Mode Downshifting Reprobate Scion FR-S / Toyota 86 GT86 General Forum 2 07-23-2012 11:40 AM
