Old 03-10-2013, 01:10 AM   #1
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
AT - Failed to downshift in manual mode
I was just on the parkway on my way home, driving my AT in manual mode and i was in 5th gear. Traffic slowed down to around 25-35mph for a couple minutes but never really went any slower than that or stopped completely or anything. As it picked back up, i hit the gas and the car would not accelerate and the rpm wasn't rising at all with me flooring the gas pedal. I glanced down and noticed the car was still in 5th and never downshifted on its own like it normally does. I manually dropped down to 4th gear and the rpm shot up from 2000rpm where it was in 5th up to around 4500-5000rpm and i was then able to accelerate and shift back to 5th as the speed increased. Any idea what would cause this? Did i just happen to end up at a speed/rpm combo that stopped it from shifting and got it stuck? Anything to worry about?
abutterman is offline   Reply With Quote
Old 03-10-2013, 01:16 AM   #2
stilletto
Drives: 2008 Mitsubishi Eclipse GS
Probably just a glitch. ..or your car telling you to buy a REAL Manual. Haha.
stilletto is offline   Reply With Quote
Old 03-10-2013, 01:32 AM   #3
abutterman
abutterman's Avatar
hopefully it was just a one time thing. no lights came on or anything. i immediately thought of the other guy who had his car just stop accelerating and die in the middle of the road. If it did die at least there was already a flat bed there pulling what looked like it might've at one point been a mustang before it became an accordion out of the trees.
Old 03-10-2013, 01:47 AM   #4
Jester
Jester's Avatar
my AT in manual mode doesn't shift down until about 1300-1500 rpm anyway...
Jester is offline   Reply With Quote
Old 03-10-2013, 03:09 AM   #5
abutterman
abutterman's Avatar
yea i just found it weird that it stayed all the way up in 5th in the 25-35mph range. usually it would've dropped down to 3rd at that speed. instead it just hung up and just wouldn't move until i manually downshifted. Only reason the rpm went up so high in 4th so quick was cause i was still pressing hard on the gas
Old 03-10-2013, 04:50 AM   #6
tim35ct
Drives: 2013 Black Brz Premium 6sp
you were in manual mode, which means you manually up n down shift
tim35ct is offline   Reply With Quote
Old 03-10-2013, 07:48 AM   #7
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
Although true, the car (really any auto with a manual mode) automatically downshifts for you when rpms get too low.
@abutterman But yea I think I've had this happen with me in higher gears as well. Never really thought much of it though as it's only happened when my car was still a bit cold. I would just downshift and go. Do you keep sport mode on when you switch to manual?
Sent from my HTC Rezound using Tapatalk 2
mezdup is offline   Reply With Quote
Old 03-10-2013, 09:58 AM   #8
FirestormFRS
That would be normal. The whole manual thing is supposed to get you more involved.
FirestormFRS is offline   Reply With Quote
Old 03-10-2013, 11:38 AM   #9
joop1987
Drives: 2013 FRS, Raven, Auto
When my car is in Auto made, it will not manually upshift at full throttle.
joop1987 is offline   Reply With Quote
Old 03-10-2013, 12:04 PM   #10
abutterman
abutterman's Avatar
sport mode was off and the car was warmed up.
Old 03-10-2013, 12:06 PM   #11
abutterman
abutterman's Avatar
although it will normally try to stay in the gear you're in, if your speed/rpm drop enough it'll downshift for you to prevent such an occurrence. never had this happen before in this car or ever in my old tc
Old 03-10-2013, 12:06 PM   #12
abutterman
abutterman's Avatar
it wasn't upshifting that was the problem. it never auto downshifted as it was supposed to leaving it in a state where the rpm was frozen where it was and could no longer accelerate.
Old 03-10-2013, 12:48 PM   #13
Auto-Hauss
Auto-Hauss's Avatar
Drives: 2013 Scion FR-S-Asphalt
If your allowing the transmission to downshift for you when you slow down in manual mode, why not just it in full auto mode? I wouldn't want to lug the engine to much. Use manual when your doing a little more spirited driving.
Auto-Hauss is offline   Reply With Quote
Old 03-10-2013, 12:58 PM   #14
abutterman
abutterman's Avatar
normally i would downshift it on my own but the thing is when you slow down and maintain that slower speed, its supposed to just take it down nice and clean to the appropriate gear. Since it normally does this, i didn't think to do it on my own.
A Week of A/T Manual Shifting Mode Ocala FR-S Scion FR-S / Toyota 86 GT86 General Forum 98 05-15-2013 02:35 AM
Manual upshift/downshift and smoothness kchkwan BRZ First-Gen (2012+) — General Topics 61 02-06-2013 07:35 PM
AT Manual Mode Easter Egg? whataboutbob Engine, Exhaust, Transmission 2 12-14-2012 11:03 AM
AT Manual Mode Downshifting Reprobate Scion FR-S / Toyota 86 GT86 General Forum 2 07-23-2012 11:40 AM
snow mode = girlfriend mode? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 9 07-01-2012 03:02 PM
