Old 06-09-2013, 01:05 AM   #1
BlackyRose
Drives: 2013 Raven FR-S
Non HID H11 Replacements
According to this post from our forum, the stock low beams are H11 and 55 watts. as anyone tried either of the below plug and play brands or lights without ordering and installing the HID kits. Please dont thread jack with comments about "why dont you just get an HID conversions kit".....I was trying to find some information about just simple direct replacement bulbs like the ones I linked below. Thanks
http://www.ft86club.com/forums/showthread.php?t=15372
http://ft86speedfactory.com/hella-op...-blue-354.html
or
[ame="http://www.amazon.com/Philips-CrystalVision-Ultra-Headlight-Bulb/dp/B00480GYSA/ref=au_as_r?ie=UTF8&Make=Scion%7C91&Model=FR-S%7C21599&Year=2013%7C2013&carId=001&n=15684181&ne wCar=1&s=automotive&vehicleType=automotive"]http://www.amazon.com/Philips-CrystalVision-Ultra-Headlight-Bulb/dp/B00480GYSA/ref=au_as_r?ie=UTF8&Make=Scion%7C91&Model=FR-S%7C21599&Year=2013%7C2013&carId=001&n=15684181&ne wCar=1&s=automotive&vehicleType=automotive[/ame]
BlackyRose is offline   Reply With Quote
Old 06-09-2013, 01:15 AM   #2
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
I picked up the crystal visions. They are better than stock but still yellow compared to the $30 5000k 35w ddmtuning hids I just installed. They just were not what I was looking for... But without going hid, they are the best you will get imho.
Sent from my Nexus 7 using Tapatalk HD
Narcoden is offline   Reply With Quote
Old 06-09-2013, 01:44 AM   #3
BlackyRose
Do you have a link for purchase or pictures of how the ddm tuning ones look on your car. Are they just a plug and play with the factory wires and projector?
Old 06-09-2013, 01:47 AM   #4
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
[ame="http://www.amazon.com/dp/B001HDW5XO"]OSRAM - Night Breaker Plus H11 (Pair) : Amazon.com : Automotive[/ame]
Old 06-09-2013, 01:54 AM   #5
BlackyRose
Originally Posted by BlaineWasHere View Post
Dead link?
Old 06-09-2013, 01:57 AM   #6
BlackyRose
http://www.vleds.com/bulb.html?cat=699
I wasn't actually looking for so much a direct replacement that was similar to stock but a direct replacement that looks more blue/white/ after market-ish
Old 06-09-2013, 02:00 AM   #7
BlaineWasHere
Grip>Drift
Drives: FRS
Originally Posted by BlackyRose View Post
Dead link?
It worked a minute ago... now it does not.
Old 06-09-2013, 02:02 AM   #8
BlaineWasHere
Grip>Drift
Drives: FRS
http://store.candlepower.com/bconibr90ulh5.html
Old 06-09-2013, 02:06 AM   #9
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
You can modify H9 bulbs to fit H11 sockets. They are 65w bulbs and should be safe. That said you can always get thicker gauge ceramic connectors. If you'll google H11 to H9 conversion you'll find a NAISOC guide. You can also find "Heavy Duty 16-GA Ceramic H11 H8 H9 Wiring Harness Adapters For Headlights or Fog Lights" on store dot ijdmtoy dot com. The should last just as long as h11's and increase the lumens to 2100. The projectors should take care of the glare from the lack of "paint/shielding" at the top of the bulb.
KKaWing is offline   Reply With Quote
Old 06-09-2013, 02:15 AM   #10
kALMIGHTY
Drives: TRD Ultramarine '13
[ame="http://www.amazon.com/gp/product/B00480KOP4/"]Amazon.com: Philips H9 Standard Headlight Bulb, Pack of 1: Automotive[/ame]
I recommend these. Output should be higher than the Philips Crystal Vision H11's, so much closer to the HID look.
I'll probably be getting these too.
Old 06-09-2013, 01:40 PM   #11
Narcoden
Narcoden's Avatar
http://ddmtuning.com/Products/DDM-HI...ast-35W-or-55W
I don't have any pics right now of them on my car, but yes, they are plug and play. The only thing is you will have a ballast to mount. You can either zip tie it in pace or use some double sided sticky 3M tape for easiest mounting. I paid the extra $3 for the mounting plates and used a self drilling machine screw to mount it in the engine bay. The whole process might take 30 mins if you completely don't know what your doing. I could put them on a car in 5 mins really. Slightly longer process than just replacing the bulbs.
If you go above 6000k for the bulbs, your lights start turning blue.
Old 06-09-2013, 01:56 PM   #12
Narcoden
Narcoden's Avatar
It's hard to see in bright daylight but they are pure white at night.
Sent from my Nexus 4
Old 06-09-2013, 04:57 PM   #13
BlackyRose
Wow those are cheap. Do you have a DIY, looks like there are some new connections to be made. I know there are diy for other companies already on YouTube. Are the instructions sufficient?
Also, what are you running for your turn signals
Old 06-09-2013, 05:14 PM   #14
Narcoden
Narcoden's Avatar
I don't have a DIY, you really can't mess it up. The plugs all only plug in one way... Watch a youtube video or 3, they all install the same. Like this: [ame="http://www.youtube.com/watch?v=H7E1r9WelZ8"]Scion FR-S | HID INSTALL DIY | LED DRL and Plate LED Upgrade DIY - YouTube[/ame]
My ballasts do not hum like the ones in this video though.
My turn signals are the 7443 60 SMD Dual color switchbacks from ddmtuning:
http://ddmtuning.com/Products/Switchback-60
Same thing the vendors are selling but nearly half the price... $29.98 for the pair. I disabled my DRL's and use the switchbacks as my fog's and/or running lights. They turn amber and blink when I use the turn signal.
JWMotoring LED light replacements sirhc Cosmetic Modification (Interior/Exterior/Lighting) 71 01-22-2014 06:50 PM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 06:48 PM
Front License Plate Replacements Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 14 05-14-2012 07:25 PM
