Old 10-07-2012, 07:28 PM   #1
sirhc
sirhc's Avatar
Drives: fr-s
JWMotoring LED light replacements
This is going to be a how to and a review for these lights. They provided me with a
Map light in white, blue, and green
Trunk light in white, blue and green
and rear plate lights in white
First off dealing with JWMotoring was very pleasant, they got the LED's to me in a timely manner. And I have had no problems with the LED's. They where sent USPS in a well padded package.
Installing the Map light was simple , I used a small flathead screw driver to remove the plastic cover, note you tilt move the rear view mirror backwards.
once the cover is off it should look like this, I removed the bulb already, also if you had your light on for any length of time you might grab it with some gloves cause it will be a little toasty
Take your new LED light pull off the adhesive from the back and stick it in the corner where there is a chunk of clean black plastic, and squeeze the metal pieces together and put the contacts in the place of the old light. note the black wire side should be towards the rear of the car
stock
white
blue
green
the plate lights are even simpler. open trunk
take the light assy and twist it to release holder
remove the bulb by slide it out
reinsert the opposite way you removed
stock
comparison
replaced white
as far as the trunk its more difficult then the others but still pretty easy
I found it easier to twist the assy to remove it
remove the light assy by squeezing the tab and pulling apart
take your flathead screwdriver and push in the tabs on the side to expose the bulb. this is the exact same bulb in the plate lights so remove the same
note you can put them in backwards and they wont work so if the light doesnt come on then remove and rotate 180 degrees
reverse the way you removed it and bam
stock
white
blue
green
sirhc is offline   Reply With Quote
Old 10-07-2012, 10:07 PM   #2
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
Very good write up thanks!
JWMotoring is offline   Reply With Quote
Old 10-07-2012, 10:36 PM   #3
_F-R-S_
Drives: 13 whiteout scion frs
just ordered.. thanks
_F-R-S_ is offline   Reply With Quote
Old 10-07-2012, 11:40 PM   #4
sirhc
sirhc's Avatar
Drives: fr-s
no problem at all, im glad I could help
Old 10-08-2012, 01:48 AM   #5
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Or buy the lights on eBay for a fraction of the cost and do a search for all the other write-ups on this forum...
Even better, buy some cheap rgb led strips with a 3 dollar controller and choose whatever color suites your current mood like I did in the wife's new mustang...
Http://photobucket.com/erinsstang
michaelahess is offline   Reply With Quote
Old 10-08-2012, 08:59 AM   #6
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
Well we do buy sponsorship here which hosts those free write-ups for members to use.
The OP was actually an installer for our products and this thread was a write up for us to use on our site.
Trust me no ebay seller is touching our warranty and support for the price
Old 10-08-2012, 01:02 PM   #7
michaelahess
Warranty and support is indeed important for many people so props to you on that. I just don't want everyone that has the DIY bug to think this is the only way to go.
Old 10-08-2012, 02:34 PM   #8
DKPJester
DKPJester's Avatar
Drives: 2013 Whiteout FR-S
Thanks for the post OP. Immediately went out and ordered a full interior/exterior set in white.
DKPJester is offline   Reply With Quote
Old 10-08-2012, 11:00 PM   #9
Fizzle
FizzRS
Fizzle's Avatar
Drives: Scion FR-S Asphalt
Sir... For The LED color which one did u pick? cus some of the have to pay extra... which one did u order?
Fizzle is offline   Reply With Quote
Old 10-08-2012, 11:41 PM   #10
vitasoy
Drives: Car
great write up and easy to follow, thanks man
vitasoy is offline   Reply With Quote
Old 10-09-2012, 02:16 AM   #11
kxbuck65ST
Drives: 2
kxbuck65ST is offline   Reply With Quote
Old 10-09-2012, 09:34 AM   #12
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
He has the full package.
Another thing to note is we're using high quality (9) SMD panels for the interior lights. These are a lot brighter than standard led bulb replacements that other sellers offer. We'll look into offering those in the future for those that just want a subtle light kit.
Old 10-09-2012, 09:58 PM   #13
Fizzle
FizzRS
Fizzle's Avatar
Ordered the complete package yesterday!
Shipment is on the way! So excited to get them and install them right away!
BTW, how do we change the color? is there like a controller?
Old 10-09-2012, 10:17 PM   #14
sirhc
sirhc's Avatar
Drives: fr-s
the only way to change the color is to get different bulbs
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 11:17 AM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-15-2013 12:15 AM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 12:21 PM
Fog light film chadz Cosmetic Modification (Interior/Exterior/Lighting) 0 06-03-2012 03:00 PM
Front License Plate Replacements Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 14 05-14-2012 07:25 PM
