Old 05-25-2013, 12:51 PM   #1
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Whiteline Camber bolt.... Help
Guys,
I'm in the process of installing the whiteline camber bolt. I've come across a snag.
See the picture. What the hell is the rectangular piece with the nipples on it for. Nothing in the instructions mention it.
FRSFirestorm is offline   Reply With Quote
Old 05-25-2013, 01:03 PM   #2
whataboutbob
AutoX-10/10ths every run
It goes under the bolt head side with the nipples facing the strut.
Build thread:Here
Old 05-26-2013, 12:16 AM   #3
FRSFirestorm
Red is Fastest
Thanks, had to get it together so they didn't make it in this go around.
Old 05-26-2013, 04:25 AM   #4
deedz
Drives: Rocket Bunny FR-S
which one is the bolt head side... just installed this yesterday and put it on the side WITHOUT the camber adjustment latch thing
Rocket Bunny Vinyl Wrapped Build Page:
http://www.ft86club.com/forums/showthread.php?t=33573
deedz is offline   Reply With Quote
Old 05-26-2013, 01:03 PM   #5
whataboutbob
I just went and looked at the directions again.
http://www.whiteline.com.au/docs/ins...ides/Z201A.pdf
I see now why you had questions. That part isn't even called out.
@Whiteline input on this one?
Build thread:Here
Old 05-26-2013, 04:27 PM   #6
jeebus
Drives: 2015 Mustang GT (on order)
are you guys able to get more negative camber from this over the OEM crash bolt?
jeebus is offline   Reply With Quote
Old 05-26-2013, 04:29 PM   #7
whataboutbob
The docs say +/- 1.5, what does the OEM do?
Build thread:Here
Old 05-26-2013, 11:11 PM   #8
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
interesting... just got my kit recently and I was wondering the same thing.
smbstyle is offline   Reply With Quote
Old 05-26-2013, 11:33 PM   #9
OrbitalEllipses
Drives: Attitude
It's for locating the bolt in slotted struts, which we don't have.
Old 05-27-2013, 02:28 AM   #10
whataboutbob
Had a look at mine this afternoon while I was switching wheels. That washer is under the nut with the nipples facing the strut.
Build thread:Here
Old 05-27-2013, 09:14 AM   #11
FRSFirestorm
Red is Fastest
What Orbital says makes sense.
Being on the nut side would make it an expensive washer. Being on the bolt head side would negate the rotating camber tab. Just my thoughts.
Old 05-27-2013, 10:38 AM   #12
infinite012
Drives: 13 DGM BRZ Ltd
I was also confused on what that piece did, so I just left it off when I was installing them last night...
Hopefully that piece doesn't matter.
infinite012 is offline   Reply With Quote
Old 05-28-2013, 11:58 AM   #13
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
My whiteline bolts did not come with that. I bought mine last fall.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 01-26-2017, 09:42 PM   #14
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
bump? no one has an answer for this?
FatFree is offline   Reply With Quote
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
FS: rce yellows & whiteline camber bolt $300 chappys4life Mid-Atlantic 19 05-13-2013 02:31 PM
[SYD] Brand new SPC 81280 16mm camber bolt (Whiteline rebrand these as their own) eckoflyte Australia Classifieds 1 03-31-2013 11:02 PM
