Old 05-30-2013, 03:21 PM   #1
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Stock rev limiter. Mine seems to be different.
test
Thorpedo is offline   Reply With Quote
Old 05-30-2013, 07:19 PM   #2
RandyP
Drives: Asphalt FRS
You misunderstand. Harsh is that it cuts RPM before resuming any sort of engine power, so it feels like you are slowing down. A soft limiter is more forgiving and just holds RPMs.
Originally Posted by Thorpedo View Post
So I have done some research about our rev limiter due to the fact that I have hit it several times in autocross.
Many people post about how our limiter is "harsh", I am taking this as it it "bounces" really hard, which is obviously hard on the drivetrain and engine itself.
Mine is completely different though. Mine has only ever "bounced" once, and it was when I was spinning the tires. I run STX class here in Atlantic Canada, I have my shift light set at 7000 and the beeper is on as well. With the windows down and my TRD exhaust I sometimes don't see or hear it, and I run it right to redline. How mine limits itself is just like I let off the throttle and I am just maintaining speed, right at redline. 100% perfectly smooth...
My only power modifications are TRD intake and exhaust.... Mine is a '13 6MT purchased from a dealer.
What I intend on doing sometime is datalogging rpm and throttle position and see if the ECU is pulling out throttle to limit rpm. I've just been so busy that I haven't had a chance. Any input on other test methods are certainly welcome!
I'll try to get a vid of this at AutoX this weekend.
RandyP is offline   Reply With Quote
Old 05-30-2013, 07:48 PM   #3
Xdragonxb0i
Drives: ex500r
i dont see a reason to hit the rev limiter, Most dyno graph shoes that 6500ish is wear we get max power.
Xdragonxb0i is offline   Reply With Quote
Old 05-30-2013, 07:55 PM   #4
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
What about the next gear? You have more available power if you shift later because it puts you higher in the power band.
Old 05-30-2013, 07:57 PM   #5
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Autocrossing and tracking often require you to hold the limiter. When you hit the limiter mid slalom, you don't shift at that point.
You dont want to shift .5 seconds before a braking zone either.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-30-2013, 08:04 PM   #6
subaruferrucci
Drives: FR-s
in autoX it isnt about power. some say shifting gear cost 3 to up up and back down. being able to hold second gear for 1 second longer and deal with the lack of power is often times quicker than going to 3rd
subaruferrucci is offline   Reply With Quote
Old 05-30-2013, 08:07 PM   #7
boredom.is.me
Custom User Title
I didn't say it was all about power. I simply made a statement.
Old 05-30-2013, 08:07 PM   #8
Hardrock4445
Hardrock4445's Avatar
I can agree with harshness. I drive AT and I can bounce limiter then shift on 1-2 shift and chirp tires. Only very few times though. It scares me....
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 05-30-2013, 08:50 PM   #9
radroach
Drives: car
rev limiter is definitely harsh, like jarringly harsh. Luckily yes the best shift point is after 6500 rpm, after that you're just noising yourself to redline.
Old 05-30-2013, 09:46 PM   #10
Thorpedo
The SquadWhisperer
Clearly you don't autocross, or if you do you're not very aggressive about it. Scion Racing pays me $500 per win as per their contingency program. A lot of the time I win my class by less than half a second. Which is where THIS applies.
I don't think I misunderstood, my car acts like it has a soft limiter. It is like I hit the cruise control button at redline. No jarring, no slowing whatsoever. I don't lose power, it is just like it backs off. I've experienced ignition cut in many vehicles before, that is the bounce I am talking about because the engine cuts spark (in most engines) at a set rpm and you lose ALL power.
Old 06-13-2013, 09:21 PM   #11
Thorpedo
The SquadWhisperer
Bump, anyone have any more info? I've done a bit more research and it definitely seems like i have a soft limiter. I always have trac disabled while doing my runs.
Stock rev limiter. Mine seems to be different. Thorpedo Scion FR-S / Toyota 86 GT86 General Forum 0 05-30-2013 03:04 PM
Top/Speed limiter for the 86? DriftEightSix AUSTRALIA 4 09-12-2012 01:53 AM
vid of dealership bouncing frs off rev limiter Big T FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 95 08-01-2012 11:54 PM
Rev limiter? feldy Scion FR-S / Toyota 86 GT86 General Forum 4 06-03-2012 10:47 PM
<3 my rev limiter NESW20 Other Vehicles & General Automotive Discussions 1 05-02-2010 11:05 PM
