Old 05-29-2013, 03:12 AM   #1
koyv90
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
sway bar lengths?
Anyone know the difference that sway bar lengths will have on the frs/brz.
For example Cusco has 2 front sway bars; 16 and 22. What is the difference?
koyv90 is offline   Reply With Quote
Old 05-29-2013, 03:24 AM   #2
rx3
That's the thickness in mm (not length).
22 mm has a much higher torsion stiffness than 16mm.
If they were solid rods the 22 mm rod would be 260% stiffer than the 16 mm rod.
rx3 is offline   Reply With Quote
Old 05-29-2013, 03:25 AM   #3
ft_sjo
Drives: GT86
I think your sums are a bit wrong there.
Old 05-29-2013, 03:36 AM   #4
koyv90
Rocket Bunny FRS
well dang i was ignorant. But what does the thickness have to do with handling?
Old 05-29-2013, 03:39 AM   #5
rx3
Torsional resistance is proportional to the diameter^3.
Example: Doubling the diameter of a rod doesn't just double its torsional stiffness but increases it by a factor of 8.
Old 05-29-2013, 03:42 AM   #6
rx3
Increasing the stiffness of the swaybar reduces body roll.
Also, increasing swaybar stiffness in the front increases under-steer.
And increasing swaybar stiffness in the rear increases over-steer.
Old 05-29-2013, 03:43 AM   #7
koyv90
Rocket Bunny FRS
what if you want to have the same settings as stock but stiffer sway bars?
Old 05-29-2013, 03:45 AM   #8
rx3
Then you would need to increase swaybar stiffness in the front and rear equally (replace front and rear sway bar).
Body roll will be reduced but the suspension will be stiffer and for instance have more difficulties to deal with potholes.
Old 05-29-2013, 03:45 AM   #9
koyv90
Rocket Bunny FRS
cool thanks for the much needed info !
Old 05-29-2013, 04:40 AM   #10
ft_sjo
Drives: GT86
Incorrect, it's ^4 (for a solid bar).
A 22mm bar is approx 360% stiffer than 16mm one. Of course once you factor in your lever arms etc. that figure goes out the window, but for a straight bar it's correct.
Old 05-29-2013, 05:44 AM   #11
rx3
You're right. I mixed it up with torsional tension which is proportional to d^-3.
Old 05-30-2013, 01:25 AM   #12
Xauterus
Drives: GTS 86 Galaxy Blue
Isn't one of the Cusco sway bars tubular?
Xauterus is offline   Reply With Quote
ST sway bars bmxhotsauce Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-09-2013 03:11 PM
CuscO Sway Bar _F-R-S_ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-18-2012 04:35 PM
Need help with sway bar purchase ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 09-22-2012 07:38 AM
Sway Bar Upgrades NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 09-01-2012 06:43 PM
STI rear sway bar carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-25-2012 12:58 PM
