Old 05-24-2013, 06:50 PM   #1
5AD86D
5AD86D's Avatar
Chirp(cricket)/Shifter TSB Posts
I am posting TSB's below. I wanted to help erase the fear for some of you guys by posting some of our Toyota TSB's on these 2 issues. First off, please understand that the chirping (cricket) noise you may be experience is normal and USUALLY disappears after 10k miles. It annoys us all abit but it definitely won't make me get rid of mine! If you continue to replace the pump after the initial job you are basically just reseting the clock on the mileage for the noise.
Secondly, for the shifter issue, the production date at bottom basically states those with that VIN number and below (ex. D1605966 and less) COULD encounter this problem. The # means any number can reside in that spot. DO NOT assume that if your VIN is below the state VIN you will be entitled to a replacement either. The process for us is to check your vehicle for the known symptoms that are pretty easy to replicate. Either way I hope this helps everyone out abit. I like everyone here love the car to so as soon as I see a new TSB I'm usually checking my own vehicle over as well.
5AD86D is offline   Reply With Quote
Old 05-24-2013, 06:59 PM   #2
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
But theres a whole thread to tsb's......
http://www.ft86club.com/forums/showthread.php?t=21868
supramkivtt2jz is offline   Reply With Quote
Old 05-24-2013, 07:04 PM   #3
5AD86D
5AD86D's Avatar
Thanks for posting that link so I don't have to gather the rest of them....I dam sure didn't wanna have to get em all...seems many may not have seen that thread as I didn't. Either way thanks for helping out.
Old 05-26-2013, 01:00 AM   #4
ft_sjo
Drives: GT86
So what's the fix for the shifter?
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
New trans, window, and cricket fix! foney_email Issues | Warranty | Recalls / TSB 11 03-14-2013 05:35 PM
Help me ID this chirp nix Issues | Warranty | Recalls / TSB 3 02-07-2013 08:00 AM
Cricket TSB - Local insight needed NickFRS Northwest 12 11-27-2012 05:32 PM
