Old 03-07-2013, 09:05 PM   #1
foney_email
foney_email's Avatar
New trans, window, and cricket fix!
So I went in for some warranty checks on some problem areas, and its going to be a long repair process.
My trans was grinding from 1st to 2nd. Diagnosis: new trans
My passengers window drivers switch is getting replaced.
The passengers window and weather stripping is also getting replaced as the window is deformed and has torn through the weather stripping.
My Bluetooth connection issues go I diagnosed and are considered a product of my iphone 5.
Amazing dealership experience and I am really appreciative of their prompt attention to my issues and a solid resolution.
For some reason, my crickets under the hood is not getting replaced, but there is an additive (or add on) that makes it quieter. Is that new? I thought everyone else got it replaced.
foney_email is offline   Reply With Quote
Old 03-07-2013, 09:17 PM   #2
OrbitalEllipses
Drives: Attitude
Dealership found no problem with my grinding 2nd, 3rd, or harsh 6th. Lucky you.
infinite012 (03-08-2013)
Old 03-08-2013, 01:49 AM   #3
Lonewolf
Lonewolf's Avatar
Drives: Moped
Is this additive something your dealer is doing on their own or is this a Toyota/Scion directed "fix" ?
Old 03-08-2013, 05:32 AM   #4
foney_email
It sounded like it was a new Toyota thing. He said additive, but I think he meant add on. I would guess its going to be sound deadening. That's just a guess, but it will be a couple weeks until he gets in the tranny, so we are scheduling only one appt. I'll let you guys know what happens with the fuel pump, but I'm sure if its a standard fix, someone else will report first.
Old 03-08-2013, 10:28 AM   #5
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Where you 1st-2nd grind only happens when car is cold? Or always?
shu5892001 is offline   Reply With Quote
Old 03-08-2013, 10:41 AM   #6
NOHOME
Drives: RAVEN
Scion tells me the grinding is normal and acceptable. This is now a standard I will apply to any potential Toyota or Subaru products for the rest of my car buying life.
What magic words did you use to get the action you are getting?
NOHOME is offline   Reply With Quote
Old 03-08-2013, 12:36 PM   #7
foney_email
If this is a common grinding issue, we will see when the trans gets replaced. It's a pretty rough grind, so I assume it was just too much to be considered normal.
I see there is a new passengers window switch for Subaru with a better logic board that works correctly. Any word on the Toyota part number?
Old 03-14-2013, 05:37 AM   #8
Nikuku
Butch Queen
Nikuku's Avatar
Drives: '13 Firestorm 6MT Scion FR-S
Send a message via AIM to Nikuku
Wow.. I take mine in next week for my first oil change, and I have to get the window switch, pump squeak (even though it's already been replaced once) and transmission/clutch looked at. Hopefully I have as good of a resolution as you! My 1st to 2nd gear switch is always labored and NOISY and there's no reason it should be that way
#Vegas86
Vegas86 Group Page on Facebook
'13 Firestorm FR-S MT "Ms. Banks"
Twitter/Instagram: Nikuku
Nikuku is offline   Reply With Quote
Old 03-14-2013, 06:42 AM   #9
sierra
Drives: Skoda Yeti DSG diesel 4x4
They probably read this forum and will give you a bottle of 2 stroke oil and a tea spoon.
sierra is offline   Reply With Quote
Old 03-14-2013, 06:23 PM   #10
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
You just suck at driving a standard.. didn't you learn in this car?
Ranatsu is offline   Reply With Quote
Old 03-14-2013, 06:30 PM   #11
OrbitalEllipses
Drives: Attitude
Get bent, loser.
Old 03-14-2013, 06:35 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would bet money that both of these issues will return.
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 10:41 AM
Engine idle chirping (cricket) noise poll. Hanzo BRZ First-Gen (2012+) — General Topics 229 02-16-2016 02:21 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 04:11 PM
Cricket TSB - Local insight needed NickFRS Northwest 12 11-27-2012 06:32 PM
How many hp more can the AT trans handle? K-R Scion FR-S / Toyota 86 GT86 General Forum 1 08-18-2012 02:21 PM
