Old 05-22-2013, 04:38 PM   #1
Aaron_blatherwick
Throttle response after intake mods
I have seen this topic on here before I just want to get a feel for how many people have seen a change in throttle response, mostly when starting from a dead stop after any intake mods. I just installed the K&N drop in Air filter and drove it the first day and was hard to tell a difference. Next day I reset the ECU and the the change was very noticeable. Almost killed the engine in 1st starting from a dead stop. Before I had to try and give it less throttle cuz it was revving so easy, as compared to my 06 tacoma. I am hoping that it gets better with the ECU re-learning proccess.
Aaron_blatherwick is offline   Reply With Quote
Old 05-22-2013, 04:56 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
The notorious dead pedal, it will go after a while once the accelerator pedal is re-learnt.
If you reset the ecu, turn the ignition to accessory mode and slowly press the accelerator to the floor 5 times (I do 6). Voila, no more dead pedal when you start it up.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-22-2013, 05:18 PM   #3
Aaron_blatherwick
Ok, I did that when I got to work but will have to wait till after to check the response. Thanks for the info!
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
5k Service and HPFP replacement, remove mods (unichip/intake)? l0aded Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-14-2013 09:49 AM
Does the throttle response improve? pr086 Scion FR-S / Toyota 86 GT86 General Forum 36 12-01-2012 01:06 PM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
