Drives: Scion FR-S Whiteout
I may have solved my shifting issues..
Ever since I got my stick FR-S, I've always had these problems with shifting:
I was driving to work today and I was thinking about that post regarding clutch engagement points. A - - - - B - - - - - - - - C A = foot off clutch B = clutch engagement point C = clutch fully depressed I realized that whenever I shift up or down, I always do it at C. So I experimented with different positions from B to C and found a good point (*) where I can shift fast, the tranny won't clunk and the car won't jerk. A - - - - B - - - * - - - - C Now, I just don't know if this will be good for the clutch long-term. I'm not revving high at the * point, and I certainly know for sure that I am shifting a lot smoother than before. Opinions?
2013 Scion FR-S
#2 | |
I try to keep my foot off the clutch as much as possible between shifts. I experience these same issues as you, but I don't think we should have to change how we shift to compensate. I think the oil swap will be the biggest gain. |
#3 | |
Sent from my Galaxy Nexus using Tapatalk 2
2013 Scion FR-S
Drives: 13' BRZ, 05' 325xi, 02' RAV4
Hey man I experienced the same problems your having when I first got my BRZ. In all honestly man, I was ready to swap out clutches with a heavier clutch because i figured it was impossible. Constantly jerking motions, the clutch was feather light and coming from heavier clutches I could not get use to it and hated it. After putting 1XXX miles on it, I can say the clutch is awesome(a little more feel would be better but work with what your given). My shifts are all smooth just level out shifts with the gas pedal, as your coming off the clutch in between shifts gradually give it gas so you smooth out the shift. Time my friend will get you to become one with the car, i have no complaints on the gearbox or clutch anymore. Give yourself a little longer and youll be in my shoes!
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
I got a cf driveshaft, I dunno how it changed it but there is no clunk anymore, it's buttery smooth, at all revs.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
I'm already at 1,2xx miles.
I wonder if this is bad for the clutch since it's not fully engaged at that point. Sent from my Galaxy Nexus using Tapatalk 2
2013 Scion FR-S
#8 | |
Drives: FR-S 6MT
smoother and I dont get the 2nd gear syncro "miss" anymore. Its still notchy when cold.. but its getting better with each drive.. I did adjust the clutch engagement point so it grabs lower to the floor.. that made a nice difference for less jerky shifts . My last car took several thousand miles before the manual felt broken in.. It gets better with use and time.. Good post.. |
When In Doubt...
Drives: Slowww
This is kind of confusing to me. Do you guys just try to push the shifter into the gear your going to, "hard and fast" ? For daily driving, you should be kind of pushing it towards the gate of the gear you want but it's a gentle motion and when the synchros are aligned just right, you can feel when it wants to go right into gear.
I say try slowing down your shift until you fully realize the "slotting in" of the gear at proper revs.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#10 | |
2013 Scion FR-S
#11 |
Drives: Subaru BRZ
I was experiencing jerks from 1st to 2ns during the first three weeks of driving (first time manual too). Slowly i began to depress and shift simultaneously, and smoothly letting go of the clutch. Then i started noticing that almost all the gears, except 1st to 2nd, you can let go of the clutch as fast as you can as long as your full release of the clutch is between 2900rpm and 3100. Now I've stop paying attention to the rev meter and just shift as fast as i can, by all means, i mean stepping on the clutch as fast as i can and shifting towards the next gear as soon as the clutch is fully pressed down, making the two motions only a split millisecond diff. While obviously releasing the clutch immediately after the shift, but smoothly. Imo i think the faster you drive, or the higher the rev you go, the faster you should shift to keep smooth, cuz i think the synchronizer is what makes the car jerky to match your shift and rev.
#12 |
Drives: 22 BRZ
I've been eyeing the DSS one hard, do you have a thread up about it? I'd like to hear more of your thoughts.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#13 |
Drives: car
#14 |
OEDC
My BRZ FI Build
| BRZ Back-up Camera and NAV Bypass SOLVED | Flat Black VW | Electronics | Audio | NAV | Infotainment | 167 | 02-13-2018 12:45 AM |
| Name that spoiler! (SOLVED) | WingsofWar | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 70 | 12-06-2014 01:22 PM |
| Torque dip reasoning solved? | Gords_zenith | Engine, Exhaust, Transmission | 33 | 03-17-2013 07:57 PM |
| BRZ won't start (Problem solved) | Dusky | BRZ First-Gen (2012+) — General Topics | 6 | 09-01-2012 09:51 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 05:09 PM |
