Old 09-01-2012, 06:45 PM   #1
Dusky
Dusky's Avatar
Drives: X3, 350z
BRZ won't start (Problem solved)
Problem solved: Loose switch connection (underneath the clutch... don't know what the name is).
The car (BRZ sports tech/ limited) won't start and is stuck at ACC mode (electrical components ON). Also the keyless access is blinking green (not yellow).
I made sure that the parking brake is set, on neutral, brakes and clutch in.
Any help is appreciated. Thanks.
Dusky is offline   Reply With Quote
Old 09-01-2012, 07:21 PM   #2
StarsGarrador
Gangnam Style Guru
StarsGarrador's Avatar
Drives: Suzuki GSXF650, WRB BRZ
Check your brake fuses. Mine had the same problem, my buddy who works in the Nissan plant blew two of my fuses with his multi meter because he had it on the wrong setting -.-
StarsGarrador is offline   Reply With Quote
The Following User Says Thank You to StarsGarrador For This Useful Post:
Dusky (09-01-2012)
Old 09-01-2012, 07:24 PM   #3
Dusky
Dusky's Avatar
Drives: X3, 350z
How do I check or where is the brake fuses. I know the brake lights works when I step on the brakes.
Old 09-01-2012, 07:28 PM   #4
StarsGarrador
Gangnam Style Guru
Under the steering wheel on the left side is one of the fuse boxes, jus use the diagram to find the right one. Can't remember where on the top of my head. Another in the engine bay. I also don't remember if my brake lights were working or not because I was way to upset haha.
Old 09-01-2012, 07:35 PM   #5
Dusky
Dusky's Avatar
Drives: X3, 350z
Problem fixed. It was a loose switch underneath the clutch. It was my own wrong doing... was trying to adjust the clutch height earlier today.
The Following User Says Thank You to Dusky For This Useful Post:
StarsGarrador (09-01-2012)
Old 09-01-2012, 07:51 PM   #6
StarsGarrador
Gangnam Style Guru
Glad you got it fixed!
Old 09-01-2012, 10:51 PM   #7
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Lol you should have said that in the first place. It didn't occur you may have done something wrong? Anyways, happy to hear the car starts
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Tad's CBS BRZ From The Start Tad_07 Member's Car Journals 8 10-12-2012 03:19 AM
Start them off young phenom86 Off-Topic Lounge [WARNING: NO POLITICS] 10 08-12-2012 04:41 PM
Honey, do...? (start over now) ToxicSneakers Off-Topic Lounge [WARNING: NO POLITICS] 0 06-14-2012 06:01 PM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 04:28 AM
push to start pa2gamer02 BRZ First-Gen (2012+) — General Topics 6 03-17-2012 02:01 PM
