Installed Over pipe,no more low end torque?
I recently installed the FT86 over pipe on my brz matching it with the q300 and catless pipe, right away ive noticed that i lost the nice low rpm torque the car used to have, i did noticed the car pulling better on 4th, 5th,6th gear which i enjoy but im trying to figure out where the low end torque went?
Thanks |
Drives: 2013 Subaru SWP BRZ Limited 6AT
That's interesting you say that. Do you have any other mods? It's common that most bolt on mods are geared toward the higher end of the rev band, but to be able to actually "feel" the loss is surprising.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
Did you disconnect the battery for any reason? The ECU may be in it's learning phase, which can feel sluggish.
#4 | |
Slower than Fast
Drives: BRZ Limited 6MT
a. reset the ECU via disconnecting the batter b. giving the ECU time to "re-learn" on its own Keep us posted on how it turns out!!!
Drives: 2013 Firestorm FR-S
As with most all NA cars, the more you open the exhaust, the more low end torque you lose. Exhaust back pressure helps scavenging, which is why going to a less restrictive, wider exhaust pipe in an NA car (from the 2.25 factory to a full 2.5 with no cats, resonators, and all straight through mufflers) will gut your low end but give you a much better top end.
It IS odd that you can feel it after a single piece, but not impossible. Rumor has it that it takes a 10hp/10 ft-lb change to be noticed, but I've never tried it. |
| The Following 2 Users Say Thank You to RedLeader For This Useful Post: | Rayme (05-17-2013), TheSlickOne17 (05-18-2013) |
I'll give the ecu more time to understand, don't wanna restart ecu and have my radio settings all jack up again
Hopefully once I installed the vortech sc kit I can get that torque back |
#7 | |
Drives: 2013 Asphalt FR-S
http://www.gomog.com/allmorgan/exhaustbackpressure.html OP, i certainly did not notice a loss in torque when i installed my nameless over / front pipe. My guess is you may be running a little richer than before but i don't know what front pipe you have.
~Namaste~ |
| The Following 3 Users Say Thank You to mad_sb For This Useful Post: |
#8 | |
#9 | |
Also, thank you for posting the link to that article, I was looking for it earlier but couldn't remember where I'd seen it. Now I can bookmark it for later when this question inevitably comes up again. |
| The Following User Says Thank You to RedLeader For This Useful Post: | mad_sb (05-18-2013) |
#10 |
Boosted
Drives: Not a supra....yet
how do you like the sound, we are debating running it on a new frs that we just got !
#11 |
I have the same with sniper but with motiv overpipe. My car had the same feel. Give the car same time to react and adapt
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#13 |
Boosted
sound wise how is it ?
#14 | |
That Guy
Drives: 2013 asphalt FRS MT
| Nameless Performance Track Pipe Installed | MTeator | Engine, Exhaust, Transmission | 46 | 09-15-2013 08:57 PM |
| Exhaust,test pipe, over pipe, headers, or suspension build | ShikoBariki | Engine, Exhaust, Transmission | 20 | 05-01-2013 04:16 PM |
| FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready | FA20Club.com | Engine, Exhaust, Transmission | 171 | 02-27-2013 09:44 AM |
| Will a resonated front pipe make alot less noise than test pipe? | Mike86 | Engine, Exhaust, Transmission | 8 | 01-26-2013 07:24 PM |
