Old 05-17-2013, 05:28 PM   #1
Sniper2606
Sniper2606's Avatar
Installed Over pipe,no more low end torque?
I recently installed the FT86 over pipe on my brz matching it with the q300 and catless pipe, right away ive noticed that i lost the nice low rpm torque the car used to have, i did noticed the car pulling better on 4th, 5th,6th gear which i enjoy but im trying to figure out where the low end torque went?
Thanks
Sniper2606 is offline   Reply With Quote
Old 05-17-2013, 05:39 PM   #2
zoomzoomers
zoomzoomers's Avatar
That's interesting you say that. Do you have any other mods? It's common that most bolt on mods are geared toward the higher end of the rev band, but to be able to actually "feel" the loss is surprising.
Old 05-17-2013, 05:44 PM   #3
wheelhaus
wheelhaus's Avatar
Did you disconnect the battery for any reason? The ECU may be in it's learning phase, which can feel sluggish.
Old 05-17-2013, 05:48 PM   #4
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
^^^^What he said. I've seen several posts here describing what you have experienced until they either:
a. reset the ECU via disconnecting the batter
b. giving the ECU time to "re-learn" on its own
Keep us posted on how it turns out!!!
MightyMeeple is offline   Reply With Quote
Old 05-17-2013, 05:49 PM   #5
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
As with most all NA cars, the more you open the exhaust, the more low end torque you lose. Exhaust back pressure helps scavenging, which is why going to a less restrictive, wider exhaust pipe in an NA car (from the 2.25 factory to a full 2.5 with no cats, resonators, and all straight through mufflers) will gut your low end but give you a much better top end.
It IS odd that you can feel it after a single piece, but not impossible. Rumor has it that it takes a 10hp/10 ft-lb change to be noticed, but I've never tried it.
The Following 2 Users Say Thank You to RedLeader For This Useful Post:
Rayme (05-17-2013), TheSlickOne17 (05-18-2013)
Old 05-17-2013, 06:30 PM   #6
Sniper2606
Sniper2606's Avatar
I'll give the ecu more time to understand, don't wanna restart ecu and have my radio settings all jack up again
Hopefully once I installed the vortech sc kit I can get that torque back
Old 05-17-2013, 07:06 PM   #7
mad_sb
Drives: 2013 Asphalt FR-S
This is an old myth. The reason larger exhausts often loose low end torque is because of reduced velocity which hurts scavenging, back-pressure does not help scavenging it hurts it.
http://www.gomog.com/allmorgan/exhaustbackpressure.html
OP, i certainly did not notice a loss in torque when i installed my nameless over / front pipe. My guess is you may be running a little richer than before but i don't know what front pipe you have.
The Following 3 Users Say Thank You to mad_sb For This Useful Post:
Calum (05-17-2013), DAEMANO (10-11-2017), Nightbringer (07-08-2013)
Old 05-17-2013, 07:27 PM   #8
Sniper2606
Sniper2606's Avatar
I have the invidia catless pipe with q300
Old 05-17-2013, 07:32 PM   #9
RedLeader
RedLeader's Avatar
Wrong verbiage, same effect; my mistake. Loss of exhaust scavenging causing a loss of low end torque.
Also, thank you for posting the link to that article, I was looking for it earlier but couldn't remember where I'd seen it. Now I can bookmark it for later when this question inevitably comes up again.
The Following User Says Thank You to RedLeader For This Useful Post:
mad_sb (05-18-2013)
Old 05-17-2013, 07:35 PM   #10
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
how do you like the sound, we are debating running it on a new frs that we just got !
Old 05-17-2013, 08:03 PM   #11
charged86
charged86's Avatar
I have the same with sniper but with motiv overpipe. My car had the same feel. Give the car same time to react and adapt
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 05-17-2013, 08:43 PM   #12
jflogerzi
jflogerzi's Avatar
I agree your AFR is probably a bit rich now. Its time for a tune
Old 05-17-2013, 08:46 PM   #13
SmsAlSuwaidi
Boosted
sound wise how is it ?
Old 05-17-2013, 08:49 PM   #14
Calum
That Guy
Drives: 2013 asphalt FRS MT
Nameless saw more power everywhere with a 3 inch exhaust vs a 2.5 inch.
Nameless Performance Track Pipe Installed MTeator Engine, Exhaust, Transmission 46 09-15-2013 08:57 PM
Exhaust,test pipe, over pipe, headers, or suspension build ShikoBariki Engine, Exhaust, Transmission 20 05-01-2013 04:16 PM
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 09:44 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
