Old 05-13-2013, 09:45 AM   #1
kasoneblaze1024
kasoneblaze1024's Avatar
Drives: white out frs
shifterrr isssuesssssss!!!!!!!
ok I know it a tsb out for the shift rattle issues ....my issues is different4 time this happen to me first 3 time was jumping to 3 or out of 3 gear shifter got stuck and rattle like a rattle snake until I braked and drop my rpms down to idle then it released the shifter...any ideas onwhats going on
kasoneblaze1024 is offline   Reply With Quote
Old 05-13-2013, 10:00 AM   #2
infinite012
Drives: 13 DGM BRZ Ltd
Try using your clutch pedal.
infinite012 is offline   Reply With Quote
Old 05-13-2013, 10:22 AM   #3
CBR600RR
Drives: Raven Black
^ or proper english for that matter
Old 05-13-2013, 10:24 AM   #4
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 05-13-2013, 10:37 AM   #5
CaptainSlow
CaptainSlow's Avatar
Take it to the dealership.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 05-13-2013, 10:59 AM   #6
kasoneblaze1024
clutch pedel wouldn't release shifter .....scion rep is coming down today to address issues
Old 05-13-2013, 11:04 AM   #7
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Originally Posted by deucethemoose View Post
LMAO i saw this on ifunny,
Marcoscrdo is offline   Reply With Quote
Old 05-13-2013, 11:30 AM   #8
Ingen
Drives: Ultramarine FR-S 6MT
The way we are interpreting what you said:
When I shift from 3-4, or 4-3, sometimes it "rattles like a rattlesnake". This is called grinding - the high pitched buzz that you get is the gear teeth skipping off one another. It's caused by mistiming your clutch release and having the clutch engage the flywheel before you are actually in gear with the shifter. As a result you usually have to move back to neutral, pull the clutch, press it again, and then shift slower. Is that accurate?
IF so.... Push the clutch, shift, then release. Problem solved, and that's what everyone's telling you!
If not, then you have a reason to chat up the scion rep.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 05-13-2013, 02:01 PM   #9
deucethemoose
Granny shifting not double clutching like you should.
Old 05-13-2013, 02:06 PM   #10
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I have another idea of what's going on, your shift is not all the way up to 3rd gear.
LeeMaster is offline   Reply With Quote
Old 05-13-2013, 02:41 PM   #11
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
+1
this was my first thought (After figuring out what OP was trying to say). Otherwise, it looks like a screwed up tranny.
Books is offline   Reply With Quote
Old 05-13-2013, 02:43 PM   #12
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I have another idea , maybe post in the issue section ?
Old 05-13-2013, 08:14 PM   #13
FnFast
Doctor
FnFast's Avatar
Drives: Fast
I was hoping someone wasn't going to post this, because I wanted to!
Jeremy Clarkson "If you go though the Pearly Gates, backwards, in a fireball, that's a cool way to die!"
2013 White Pearl BRZ Limited 6MT - 15% Tint, Debadged, HIDPowerhouse LED Interiors and Dome
FnFast is offline   Reply With Quote
Old 05-22-2013, 12:50 PM   #14
kasoneblaze1024
got my gear box replace..... it was internal ... notyhing to do with the tsb ... or clutch
