Drives: white out frs
shifterrr isssuesssssss!!!!!!!
ok I know it a tsb out for the shift rattle issues ....my issues is different4 time this happen to me first 3 time was jumping to 3 or out of 3 gear shifter got stuck and rattle like a rattle snake until I braked and drop my rpms down to idle then it released the shifter...any ideas onwhats going on
#2 |
Drives: 13 DGM BRZ Ltd
Try using your clutch pedal.
#3 |
Drives: Raven Black
^ or proper english for that matter
#4 | |
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
#5 |
Take it to the dealership.
Ultramarine 2013 Scion FR-S 6MT
#6 |
#7 |
Drives: 13' DGM Built FBM BRZ
#8 | |
Drives: Ultramarine FR-S 6MT
When I shift from 3-4, or 4-3, sometimes it "rattles like a rattlesnake". This is called grinding - the high pitched buzz that you get is the gear teeth skipping off one another. It's caused by mistiming your clutch release and having the clutch engage the flywheel before you are actually in gear with the shifter. As a result you usually have to move back to neutral, pull the clutch, press it again, and then shift slower. Is that accurate? IF so.... Push the clutch, shift, then release. Problem solved, and that's what everyone's telling you! If not, then you have a reason to chat up the scion rep. |
#9 |
Granny shifting not double clutching like you should.
#10 |
Red wine
Drives: Subaru BRZ(R.I.P)
I have another idea of what's going on, your shift is not all the way up to 3rd gear.
#11 | |
Drives: Ultramarine FR-S (MT)
this was my first thought (After figuring out what OP was trying to say). Otherwise, it looks like a screwed up tranny.
#12 |
Boosted
Drives: Not a supra....yet
I have another idea , maybe post in the issue section ?
#13 |
Doctor
Drives: Fast
I was hoping someone wasn't going to post this, because I wanted to!
#14 |
got my gear box replace..... it was internal ... notyhing to do with the tsb ... or clutch
