Old 04-30-2013, 08:52 PM   #1
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
camber adjustment
How much would 1°-1.5° of camber affect the life of the tire. Would there be obvious tire wear on the side walls? Thx for your input :-)
SMOKETREES is offline   Reply With Quote
Old 04-30-2013, 09:04 PM   #2
PANDA86
Old School Status
Drives: .
depending on the width, air pressure and toe will have different results.
i've had -3 to -5 camber on my previous daily driven bB on 15x8 195/50 32psi and the -3 lasted for 8-11 months. -5 for 5months. proper toe correction will minimize wear.
PANDA86 is offline   Reply With Quote
The Following User Says Thank You to PANDA86 For This Useful Post:
SMOKETREES (04-30-2013)
Old 04-30-2013, 10:32 PM   #3
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Hsvent changed toe and probably won't cause I know changing toe can really mess with tire wear unevenly so that'll stay stock. I'm running about 35 psi in tires and my wheel size is, 18x8.75
Old 05-01-2013, 02:23 PM   #4
kioton32
kioton32's Avatar
Drives: 14' Monogram FRS, ulramarine, white
It also depends on the compound of the tire as well
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
kioton32 is offline   Reply With Quote
The Following User Says Thank You to kioton32 For This Useful Post:
Trap63 (05-02-2013)
Old 05-01-2013, 02:25 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
when you change camber your toe will change
so if you're doing this yourself don't assume that you can just crank your camber bolts/plates and stroll along.
Old 05-01-2013, 11:19 PM   #6
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
QFT.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
The Following User Says Thank You to SportInjected For This Useful Post:
Trap63 (05-02-2013)
Old 05-26-2013, 04:39 PM   #7
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Toe will affect wear much more than camber.
raul is offline   Reply With Quote
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
KW V3 camber adjustment olorin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-28-2013 04:46 PM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 10:46 AM
