Old 04-29-2013, 11:02 PM   #1
Greg Gellas
Greg Gellas's Avatar
Drives: S2000, Acura TSX
Cool FRS Contamination Removal and Opti-Coated in NJ by Signature Detailing, Greg Gellas
After, Finishing up @kykiee BRZ Saturday I then moved on to a FRS on Sunday. I didn't have the time to do a full write up on Ky's car
For Sunday I was taking care of a Raven Black FRS. My inspection showed light and deep swirls and scratches, along with contamination over the entire surface.
I began with the wheels and tires. The wheels where cleaned with Sonax Full Effect, wheel woolies, and a boars hair brush. The tires were scrubbed with Tuffshine tire cleaner and a Tuff shine tire brush. As you can see, the tires needed a good cleaning.
The entire car was splattered, in what I could only describe as a tar/sap like consistency contamination. It would smudge, but the only way to totally remove it was with a Nanoskin Autoscrub Wash Mitt.
I began with a foam wash to add lubrication.
I then used the foam as a lubricant for the Nanoskin Wash Mitt. It removed all of the contamination from the surface. Slow, light movements are key, or else it can Marr the paint. This alone, full removal took what seemed like FOREVER.
I dried the entire car using a waffle weave drying towel and my Chemical Guys Jet Speed blower for the cracks. I began correction using Sonax Perfect Finish and a Rupes Yellow pad on my Rupes LHR15. I chose the 15 over the 21 due to the curves the FRS has. I was only doing a 1 step correction but wanted to get as much as I can, as always. I decided to do a 50/50 showing exactly how much correction I was able to get with a 1 step. For a 1 step polishing I was able to get 90% of the defects out. Some of the deeper ones were still there, but you really had to look for them.
Following correction, I washed the entire car again to remove any dust and polishing oils. This was followed up with a complete IPA wipe down. I found some wax that needed to be removed. I then proceeded to coat everything with Opti-Coat Pro. This coated all of the paint, trim, and rear valence. I even went as far as adding Opti-Glass to the windshield.
The Exhaust tips got cleaned up with Optimum's Metal Polish, and a MF towel.
For the tight areas a foam detailing stick was used. I dressed the tires with a wonderful tire gel made by Garry Dean.
Please excuse the lack of afters on the exhaust tip, none came out. You can see the tips in some of the final pics.
As always thanks for looking! Greg Gellas@SignatureDetailing
Greg Gellas is offline   Reply With Quote
Old 04-29-2013, 11:09 PM   #2
DJ Mayo
Drives: 2013 WRX Limited
EXCELLENT photos and work, Greg!
DJ Mayo is offline   Reply With Quote
Old 04-29-2013, 11:19 PM   #3
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
Good job Greg!
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 04-29-2013, 11:25 PM   #4
Greg Nichols
Paint Correction Guru
Greg Nichols's Avatar
Drives: F150 Platinum
Well done Greg!
did you use the Opti glass pro?
Cheers,
GREG
Reflections Detailing of Utah
"Detailing for the discerning owner"
Meguiars/Ford detailing team SEMA 2010 and 2011
Ask a pro blog writer for detailed image
duPont Registry approved detailer
Greg Nichols is offline   Reply With Quote
Old 04-29-2013, 11:28 PM   #5
Greg Gellas
Originally Posted by Greg Nichols View Post
Well done Greg!
Cheers,
GREG
Of course!
Old 04-29-2013, 11:45 PM   #6
9major
Drives: x
You did an awesome job Greg, very happy with how it came out.
9major is offline   Reply With Quote
Old 04-30-2013, 02:34 AM   #7
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Impressive work, the world needs more people like you, people with pride.
Old 04-30-2013, 06:09 AM   #8
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Awesome work. I think that tire gel has a beautiful shine to it.
greg gellas, new jersey detailing, opti-coat, paint correction, signature detailing
911C4S and Audi A6 Corrected and Opti-Coated by Greg Gellas Greg Gellas Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 06-07-2013 08:17 PM
900 Mile hammered FRS Opti-Coated by Greg Gellas Greg Gellas Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 03-18-2013 04:18 PM
Black Diamond CTS-V gets coated in 22PLE by Greg Gellas Greg Gellas Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 03-14-2013 12:29 AM
New Car Opti-Coat BRZ by Greg Gellas Greg Gellas Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 01-27-2013 02:34 PM
Greg Gellas Opti-Coats a FRS Greg Gellas Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 01-20-2013 08:55 PM
