| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: S2000, Acura TSX
Black Diamond CTS-V gets coated in 22PLE by Greg Gellas
I was recently contacted for a correction and coating on a Cadillac CTS-V Black Diamond Edition. What is it exactly that makes the "Black Diamond Edition" Special?
“Black Diamond offers the discerning Cadillac customer a special option color that stands out and remains true to their sense of luxury and style." 'Posted on 02.3.2011 07:00 by Simona' "What sets the Black Diamond Edition apart is specialized tri-coat paint from California-based JDSU. A look of diamonds in the SpectraFlair pigment in the paint is created by using aluminum flakes encapsulated in a glass-like substance called magnesium fluoride, GM said." -Suzanne Ashe February 7, 2011 I began with the wheels, I don't want to be down and dirty in the wash water, which is why I always start with the wheels. I power washed the tires, rims, and wheel wells. There was lots of tire sling stuck in the wheel wells. ![]() Using sonax FE and wheel woolies, the wheels were cleaned and the tires were scrubbed with power clean. ![]() Now it is time for a bath. I foamed the car with a mixture of dawn and Chemicals Guys Citrus Wash and Clear. http://i197.photobucket.com/albums/a...ps47712715.jpg Now that we are down to paint and no wax or fillers, we can see the real damage to this amazing paint! ![]() ![]() ![]() ![]() ![]() After seeing all the wax residue, I knew I would have to rinse it one more time. I went around with a china brush and removed all the dried-on wax in the vehicles seams and edges of clear bra. ![]() ![]() ![]() Here you can see why I had to rinse again. All the dust from the wax removal was every where. You also can see that the wax is gone ![]() ![]() The front bumper, hood, fenders, and doors were all covered in paint protection film. This can be tricky to correct. After, I pulled it in and got to work. Starting with the clear bra correction there was a larger marr on the clear bra. The rest of the paint recieved a polish with a Rupes yellow pad, and Sonax Perfect finish. ![]() Without heating too much and potentially twisting the bra I got as much correction as I felt comfortable with. If you get too aggressive with PPF you can heat it too much loosening the adhesive causing the film to acutally twist. ![]() I moved on to correct the tail lights. ![]() ![]() I was also applying Car Pro flyby30. I started with a complete scrubbing using Ceri-Glass. With any coating, whether it be paint or glass or trim, proper prep is the key! ![]() After the polishing and Ceri-Glass, the car needed a bath. I needed to remove any polishing oils off of the paint surface. ![]() I brought it back in and dryed it completely, using my CG Jetspeed blower and a WW MF towel. I moved on to apply FlyBy30 in a crosshatch pattern. ![]() Flyby30 requires an IR curing or heating the of the glass to 80 degrees. I use a heater and aluminum foil to trap the heat and accelerate the coating. ![]() So after five minutes of cure time of FlyBy30, I was ready to do a IPA wipe down and then apply 22PLE to all the paint and even the clear bra. ![]() The piano finish on the interior got a hand polish and was also coated with 22PLE. ![]() Please excuse the blurry after picture, but you can see the correction I got. ![]() I moved on to polishing the metal areas, including the exhaust tips and strut tower bar. They were then coated with 22ple metal and wheel coating. ![]() The wheels were also removed and the barrels, faces, and calipers were coated with the metal and wheel coating. One of the wheels had a scuff on it, so the owner supplied an extra wheel to have coated before the tire gets transferred. ![]() All of the plastic and trim also receive 22ple trim restore. ![]() ![]() By now I am sure you are bored with my long winded style SO, on to the glory shots. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() As always, thanks for looking. Greg Gellas
| New Audi S6 gets 22PLE by Greg Gellas | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 03-10-2013 06:32 PM |
| Nissan GTR New Car Opti-Coat by Greg Gellas | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 16 | 02-14-2013 12:47 PM |
| New Car Opti-Coat BRZ by Greg Gellas | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 01-27-2013 02:34 PM |
| Greg Gellas Opti-Coats a FRS | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 17 | 01-20-2013 08:55 PM |
| Opti-Coat by Greg Gellas AKA SignatureDetailing | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 12-31-2012 04:40 PM |
