Old 01-21-2013, 01:05 AM   #1
Greg Gellas
Greg Gellas's Avatar
Drives: S2000, Acura TSX
New Car Opti-Coat BRZ by Greg Gellas
Here I go again! New BRZ getting Opti-Coat. I initially inspected the paint, and suggested to the owner that the clarity was good enough to forgo the 1 step correction and just get a prep and coating. This would not only save the client some money, but the amount of gloss I would have added wouldn't be noticeable enough to anyone but a perfectionist. After seeing the paint under some lights he agreed.
I started with the wheels and tires. I wet the wheels, then spray them down with Sonax Full Effect, and let that dwell. The tires got scrubbed with Tuff shine Tire cleaner. Wheel wells were scrubbed with P21S TAW and a Ez Detail Brush.
The wheels then got cleaned with Wheel Woolies to ensure the inner barrels where fully cleaned also.
Now I was ready to wash the majority of the car. I pre-soaked the entire car in Optimum Power Clean and proceeded to foam it using a mixture of 50% Chemical Guys Citrus wash and clear and 50% Dawn. Dawn can be drying to the paint but to ensure complete removal of any sealants or waxes it can be useful. I wouldn't use it as a weekly wash.
After a wash I proceeded with the Nanoskin wash mitt, it is basically a clay bar in mitt form.
Around the entire interior glass their was adhesive residue left from stickers.
For a safer removal I decided to use Tarminator. Its clear coat safe, and my go to adhesive remover.
As you can see after a quick wipe with a MF towel soaked in tarminator it easily "melts" the residue.
Once it is all removed from the surface you are left with the adhesive spread out over the window or panel, simply flip the MF towel to a new side to remove and follow with invisible glass.
After claying and polishing the windshield, FlyBY30 was applied, after about a minute I buffed it off
Often times, you are able to simply remove adhesive by rolling it onto itself. This time completely pulling it off in one strip was the key. Reducing the use of a razor blade can be helpful as you never know when you can scratch the glass with the razor.
Here I removed the badge residue. We had another badge removal which has become very common with the BRZ owner.
Once the badge is removed, one can simply roll the adhesive onto itself.
The residual adhesive was removed using, guess what?! Tarminator, then lightly polished to ensure that there was no shadow left.
Getting down to the details is what we do. The four wheel locks had adhesive on each of the heads.
Using a make up remover tool, I soaked the head in Tarminator and agitated.
Paper of course ended up in the "seams" of the wheel lock. I simply turned it around and used the pointy side to remove any paper.
That works!
The exhaust tips were corrected using my standard foam detailing stick with Optimum Metal Polish.
OOPS too soon for the picture! I didn't finish polishing the entire exterior. I caught it and fixed it.
As usual, I was coating the tires using the Tuff Shine Tire Coating. To ensure it bonds, the tires have to be perfectly clean. This was the third cleaning.
Ok, now it's time to get to coating the car. Every inch got a wipe down with IPA, including the the wheels and trim. Now its time to apply Opti-Coat!
Even the key fab got an IPA and Opti-Coat.
I wanted to let the Opti-Coat sit for a little therefore I moved on to the interior. Remember to get the inside of the windshield really good. It can be a difficult area for clients to get streak free.
What did I end up with and how does it look in the sun?
As always thanks for looking!
Greg@Signaturedetailing.com
Greg Gellas is offline
Old 01-21-2013, 06:49 AM   #2
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Amazing job once again. How's it using the Nanoskin wash mitt? Anything you like or dislike about it?
ZetaVI is offline
Old 01-21-2013, 09:37 AM   #3
raptor87
Drives: 2013 DGM BRZ Ltd
Turned out awesome, I highly recommend Greg if you are in the area.
raptor87 is offline
The Following User Says Thank You to raptor87 For This Useful Post:
Greg Gellas (01-21-2013)
Old 01-21-2013, 09:48 AM   #4
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Good job. I see a Texas Chain Saw Massacre mask in this pic (top right corner). What do you use that for? It's a little creepy :/
chenshuo is offline
Old 01-21-2013, 04:07 PM   #5
RidetheTran
Drives: Toyota
More like Jason's mask from Friday the 13th
RidetheTran is offline
Old 01-21-2013, 04:31 PM   #6
Greg Gellas
It's similar to their other products. I have their pads, and towel also. They should all be used with care, but can speed up decon time greatly.
Old 01-27-2013, 02:34 PM   #7
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
I'm from north-east PA and I'm planning on getting an FR-S in the spring. How much do you get for such a service? I'm hoping to get an opti-coat done as soon as I can after purchasing the car, provided I can afford it.
FReSh is offline
Opti-guard / Opti-coat detailers in Richmond? xjohnx Mid-Atlantic 10 02-05-2013 10:33 AM
Greg Gellas Opti-Coats a FRS Greg Gellas Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 01-20-2013 08:55 PM
New Years Eve Opti-Coat by Greg Gellas Greg Gellas Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 01-07-2013 04:05 PM
Opti-Coat by Greg Gellas AKA SignatureDetailing Greg Gellas Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 12-31-2012 04:40 PM
Calgary Opti-guard/Opti-coat Detailer Kevstra CANADA 12 12-26-2012 02:53 AM
