Drives: 2013 FRS
exhaust buzzing 3k to 4k input please!
so have I have the ARK test pipe as well as catback exhaust and have an issue with the exhaust rattling around 3k to 4k when the throttle is pressed more than halfway, so kinda laying in on it. I have checked to see if the bolts were loose and there is no sign of anything being loose at all. I also checked the heat shield on the exhaust manifold and nothing is loose there. Mind you the test pipe does not have a heat shield so there can't be anything going on there. Since I do not have or know the torque specs for the exhaust, I tightened down everything pretty tight with an impact gun. I have noticed something though, which is condensation (not much) going from the test pipe to the catback where the donut gasket is. That portion I really tightened down in fear of it coming loose. Could this be the issue since there is not enough play in the system? Perhaps I over tightened that part of the exhaust? Any input would be great!!!
Note: mind you only in more than half throttle around 3l to 4k the noise happens otherwise it's gone. Otherwise if not on more than half throttle, the exhaust sounds perfectly fine without the noise. Last edited by ft86me; 03-23-2013 at 11:41 PM. |
there shouldn't be any sort of leakage.. and given that you noticed some condensation at the donut gasket, it might possibly be the linkage between test-pipe and catback that's making the rattle sound.
Call/email ARK and see what their opinion is on it. |
Drives: 2013 Subaru BRZ MT Limited
You very well could have overtightened something...the exhaust bolts only need to be tightened to 25 ft-lbs...tightening with an impact means they are probably closer to 125ft-lbs which could warp flanges.
Also check clearances around the transmission tunnel and those things, the Perrin had an issue where on some cars the resonator did not have enough clearance between the resonator and the trans tunnel and would hit the trans tunnel and make noise, easily fixed with a couple minor adjustments.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#4 | |
Drives: 2013 FRS
i'll definitely check that out. thanks man appreciate the info. wow 25ft lbs. fml hahaha. perhaps too late. i'll put it in the air on monday and see what's going on at work. thanks again! |
#5 | |
Drives: 2013 FRS
Drives: Subaru BRZ
What you may be hearing is rasp from the test pipe. That is a common problem. The torque spec for the donut gasket is just 15 lbs.
Drives: 2013 FRS
Drives: 2013 FRS
Red wine
Drives: Subaru BRZ(R.I.P)
I have this problem, the exhaust is hitting the crossmember right in the center of where the rear wheels are. The solution for me was slightly longer stiffer polyeutherane exhaust hangers.
#10 |
Drives: 2013 FRS
i can hear mine coming from the front for sure. it's like the front right. doesn't sound like a rattling on something and plus I have the exhaust hangers wrapped with clamps so they don't sag
#11 |
Drives: Subaru BRZ
Yes. I have the same problem with the condensation but haven't been able to completely stop it.
#12 | |
Drives: 2013 FRS
mine is SUPER minimal i mean not even enough for it to drip on the ground. i hit up ark with an email a few minutes ago so i'll find out what's going on next week. they are nearby me so if anything i can take it down there |
| Buzzing / Compressor Sound from Gas Tank Area | Spd229 | Issues | Warranty | Recalls / TSB | 14 | 12-06-2013 10:17 PM |
| FRS-off/rear wheel buzzing... | iaclimber4 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-31-2013 06:25 PM |
| Intermittent buzzing from below the steering wheel? | brzninja | BRZ First-Gen (2012+) — General Topics | 12 | 01-05-2013 10:01 PM |
| Delete | driver01 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 11-15-2012 01:00 AM |
| buzzing noise from steering wheel FR-S | :DK | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 10-07-2012 01:52 AM |
