Old 04-29-2013, 01:11 PM   #1
ckcrown84
Stereo + Rear Brake Rattle
I have been searching high and low to find a easy fix to the rear brake light rattling--without actually removing it!
Looking for some quick solutions some of you may have come up with?
I was thinking maybe buy 2 clear rubber stoppers and wedge them under the plastic so that it can't move... not really sure...
Please provide some feedback!
ckcrown84 is offline   Reply With Quote
Old 04-29-2013, 04:02 PM   #2
cruzinbill
Drives: Argento 6spd FR-S
Just deaden the rear deck and cover
cruzinbill is offline   Reply With Quote
Old 04-29-2013, 04:44 PM   #3
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Go in your kitchen and open one of the cabinets. Peel off two of those rubber bumpers and wedge it in between the brake light and the back window. ...or just go buy them anywhere for $1.
rmjjensen is offline   Reply With Quote
Old 04-29-2013, 05:39 PM   #4
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Is there a DIY on how to take it apart?
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 04-29-2013, 06:11 PM   #5
cruzinbill
yes..... comes up as at the top of search results.
http://www.ft86club.com/forums/showt...r+deck+removal
The Following User Says Thank You to cruzinbill For This Useful Post:
cfusionpm (04-29-2013)
Old 04-29-2013, 06:46 PM   #6
ckcrown84
I was going to buy two CLEAR rubber stoppers but can't find them online because I am probably retarded but will look again tonight.
Old 04-29-2013, 06:47 PM   #7
ckcrown84
the rear deck is all deaden with dynamat, but it is not solving the problem of that brake light...
Old 04-29-2013, 08:05 PM   #8
cruzinbill
if you put enough mat and then used foam as well it presses the light tight enough against the window it wont resonate
Old 04-29-2013, 09:24 PM   #9
ckcrown84
The shop that did my work said that if they did that it might resonate against the glass and create a whole new set of problems for me...
I am thinking to try the rubber stoppers, and if that doesn't fix it then find a shop that will remove it... I am not a DIY kinda guy unfortunately.
Old 04-29-2013, 09:32 PM   #10
ckcrown84
http://www.lowes.com/Hardware/Specia.../N-1z0yk90/pl#!
Any recomendation on what size I should go with?
I was thinking a 2" stopper?
Old 04-29-2013, 09:47 PM   #11
cruzinbill
So you didnt do the deadning, someone else did? Was enough used and properly done?
I have 0 rattles or resonance anywhere in the car now, the doors and rear deck is where 90% came from. If the rear deck was done right it really shouldnt really need foam pad, but some cases its needs some still.
If you dont mind seeing the stoppers in there tho, sure give it a shot.
Old 04-29-2013, 09:52 PM   #12
ckcrown84
It was "professionally done" at a local car audio shop. They said they couldnt get it as good as they wanted (rattles) so he took 100 dollars off the bill (initially 200 for deadening, dynamat, and installation of front dash speakers)
Old 04-30-2013, 09:08 AM   #13
rmjjensen
rmjjensen's Avatar
You should be looking for the rubber bumpers used for cabinets:
http://www.lowes.com/Search=cabinet+...abinet+bumper#!
Old 04-30-2013, 09:29 AM   #14
infinite012
Drives: 13 DGM BRZ Ltd
Use rubber gasket and wrap the perimeter of the third brake light? Like those c-channel rubber strips people use to wrap holes in the firewall.
infinite012 is offline   Reply With Quote
Solution Found: Rear Deck Rattle jdubz Issues | Warranty | Recalls / TSB 29 10-13-2019 03:48 PM
Solution Found: Rear Deck Rattle jdubz DIY (Do-It-Yourself) Guides 31 08-23-2015 06:08 PM
Rattle in rear left of car - Need some help! eleu2166 AUSTRALIA 4 12-01-2012 10:51 AM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 05:35 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
