Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 11-30-2012, 07:21 AM   #1
eleu2166
Drives: '07 Civic Type R
Rattle in rear left of car - Need some help!
Hey guys,
So my cars developed a pretty loud rattle (comes and goes though) near the left rear wheel (outside the car). Here's a sound clip, I was cruising in a quiet parking lot with windows down (loudest at 20sec mark):
http://dl.dropbox.com/u/497649/Memo.m4a
Since I had some suspension mods (sway bar, rear bushings, coilovers), first thing I did was bring it back to my mechanic. They tightened everything and the sound didn't go away. Brought it to back Toyota (Peter Warren), who said they will not fix it as the suspension has been modified.
I then had a look under the car and found that when hit or moved the circled bracket below makes a similar noise to the rattle. (Note: This bracket/sensor appears to be missing from GT models).
You can easily access and see this bracket if you look under the rear left side of your car. Here's a video of me hitting the bracket:
[ame="http://www.youtube.com/watch?v=erXNBpO3ZoE"]IMG 1720 - YouTube[/ame]
Now, my question is, is this normal? If anyone has some free time, can you hop under the rear of your car (car does not need to be jacked up) and see if you can reproduce what you see in my video? If not, then at least I may have found the source of the sound.
BTW, stay away from Peter Warren Service Center (@newft86 Andrew Smith you're still great though!), very unprofessional bunch of guys. Stalled my car three times while taking it out on a test drive, and called my suspension mods 'bullshit' when he was explaining that Toyota will not fix the rattle under warranty.
eleu2166 is offline   Reply With Quote
Old 11-30-2012, 09:26 AM   #2
Nardi330
Nardi330's Avatar
Drives: 86
That looks like the HID self leveling sensor. I'll have a look at mine tomorrow. Have you lowered too much?
I have coilovers and the same subframe bush (factory swaybar) and no sound.
Is the sensor hitting the sway bar or exhaust pipe? You have Whiteline sway bars right?
Nardi330 is offline   Reply With Quote
Old 11-30-2012, 09:41 AM   #3
eleu2166
Only been lowered 15mm. Yeah Whiteline swaybar, but it doesn't appear to be hitting the swaybar or exhaust, need a closer look to see what it's hitting.
Old 12-01-2012, 08:05 AM   #4
eleu2166
So we went ahead and tightened the bracket itself and the bracket no longer rattles or clanks when hit. But unfortunately the rattle I wanted to fix is still there. Problem is that it's very intermittent, comes and goes, sometimes loud, sometimes soft, very very difficult to diagnose.
Old 12-01-2012, 09:51 AM   #5
eckoflyte
Drives: Toyota 86 GTS
I would start with the assumption it's a mod you've done to create the sound. Start with the swaybar and try putting in the stock swaybar and see how it goes. Trial and error.
eckoflyte is offline   Reply With Quote
Mileage when you left the dealer? neutral Scion FR-S / Toyota 86 GT86 General Forum 78 03-03-2020 12:27 PM
Solution Found: Rear Deck Rattle jdubz Issues | Warranty | Recalls / TSB 29 10-13-2019 02:48 PM
Solution Found: Rear Deck Rattle jdubz DIY (Do-It-Yourself) Guides 31 08-23-2015 05:08 PM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 04:35 PM
I saw, I went I left a deposit :D 86design BRZ First-Gen (2012+) — General Topics 350 02-29-2012 09:32 PM
