Old 04-27-2013, 08:11 PM   #1
mad_sb
Drives: 2013 Asphalt FR-S
flipping the headrest
OK, so i have done a few track days now in the FR-S and each time I end up flipping the headrest around backwards to make "room" for the helmet. With the headrest in the normal position it feels like it pushes my head down with the helmet on which makes sense because it is designed to provide restraint for an bare head.
With the headrest flipped around though it feels like there is very little head restraint with a helmet. Granted, it is more than with headrest removed, which is why i run it flipped.
Has anyone looked for or found an alternative head rest that works well with the stock seats and helmets?
Eventually I will be doing a back half cage and 4 point ASM belts (while the car is dual purpose). For cost reasons I would like to be able to use the stock seats as long as possible.
Old 04-27-2013, 08:16 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
I found raising the headrest to maximum height with it oriented normally doesn't push as much with helmet on. The headrest pushing down makes me not look as far down track.
JDKane527 is offline   Reply With Quote
Old 04-27-2013, 11:50 PM   #3
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
I remember reading somewhere that the headrest was designed to be flipped around while wearing a helmet.
Tapped from my Note 2
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 04-28-2013, 12:17 AM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
This
mashal is offline   Reply With Quote
Old 04-28-2013, 07:25 AM   #5
mad_sb
As i said, I have been fliping it. But with it flipped it does not provide much if any real head restraint and does not feel much safer than having no head rest.
Has anyone looked for an alternative that will fit the factory seat?
Old 05-18-2013, 06:22 AM   #6
grodenglaive
Drives: asphalt FR-S
I am concerned about that too. You could also try putting the seat more upright so your head/helmet is closer to the headrest. Alternatively angle the seat back more and raise the headrest so there is more room for your helmet (without flipping the headrest).
I'm going to try some different helmets. A racing specific helmet (snell SA rated) may have a flatter profile at the back than a motorcycle helmet, which tend to be elongated for aerodynamics. Then maybe I won't need to flip the headrest.
grodenglaive is offline   Reply With Quote
Old 05-18-2013, 11:12 AM   #7
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
I'd stay away from a 4 point. Most track day organizers won't even let you on track with a 4 point.
GTM_Challenge is offline   Reply With Quote
The Following 2 Users Say Thank You to GTM_Challenge For This Useful Post:
DylanFRS (05-18-2013), WillRacer1jz (05-20-2013)
Old 05-19-2013, 02:15 AM   #8
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
I never thought of this
I have a track day coming up in this weekend. I'll let u guys know my feed back
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
The Following User Says Thank You to Doborder For This Useful Post:
Godzilla35 (05-19-2013)
Old 05-19-2013, 04:02 AM   #9
Godzilla35
Drives: Nissan GT-R
interested in the info as well... thanks for looking into it
Godzilla35 is offline   Reply With Quote
DIY - video camera mounted to drivers headrest nzer DIY (Do-It-Yourself) Guides 1 01-06-2013 12:21 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 01:28 PM
Headrest issue? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 11 12-01-2011 03:48 PM
