Old 04-27-2013, 05:30 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Would a taller / larger oil filter improve oil cooling?
I'm sure not as much as a true cooler but would a filter say double the height help at all?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 04-27-2013, 05:45 PM   #2
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
It's only a filter that is located in the engine bay(HEAT), it is not an air filter where it would suck in cool air. The oil filter's job is to filter metal shavings and/or dirt that somehow made its way into the engine through the dipstick or loose oil cap.
If you are looking for an oil cooling solution, get an oil cooler.
If you can somehow manage to get an oil filter that is 20" long that pops out of the hood, that may work as a cooling solution. jk
LeeMaster is offline   Reply With Quote
Old 04-27-2013, 11:16 PM   #3
FT_Monk
Drives: Over the hill WRX
If it fit, it does not hurt. The bigger the filter, the better the oil flow and more oil capacity means better cooling, of course not as much as an oil cooler. There is no need to go to the extreme like an oil cooler if your engine stay near stock. Not to mention oil cooler presents its own problem, leaks, can't replace all the oil, too cold....
FT_Monk is offline   Reply With Quote
Old 05-14-2013, 02:21 AM   #4
D1cker
Drives: B9 S4/ND2
It won't do much of anything, no airflow and no real way to disperse heat.
D1cker is offline   Reply With Quote
Old 05-14-2013, 02:42 AM   #5
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You won't have to worry about oil temps if you use an engine bypass kit.
http://kalecoauto.com/index.php?main...products_id=40
Old 05-14-2013, 03:11 AM   #6
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Nice LOL
nzer is offline   Reply With Quote
Old 05-14-2013, 03:18 AM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Wow, now there's a site to waste 6.5 minutes!
Will there be a larger TRD aftermarket and When? corvino26 Scion FR-S / Toyota 86 GT86 General Forum 17 12-10-2012 04:22 PM
Does the throttle response improve? pr086 Scion FR-S / Toyota 86 GT86 General Forum 36 12-01-2012 01:06 PM
First 1k miles, 5 small things I hope improve in time regal Scion FR-S / Toyota 86 GT86 General Forum 6 10-03-2012 11:15 AM
What to replace first to improve audio? garsh0p Electronics | Audio | NAV | Infotainment 1 06-21-2012 06:05 PM
Tips, tricks, techniques to improve driving? Buggy51 Off-Topic Lounge [WARNING: NO POLITICS] 15 08-01-2011 04:17 PM
