Old 04-22-2013, 02:26 AM   #1
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
Lowest possible offset for 18x9.5? and 255's?
+30 is the on 225's shown here: http://www.ft86club.com/forums/showthread.php?t=11258
+25 on 225's shown here: http://www.ft86club.com/forums/showthread.php?t=17083
I saw Jive Turkey's car and he's running 265's on a +40 so I'm hoping maybe I could squeeze a 255 +28 in there. His car is here: http://www.ft86club.com/forums/showthread.php?t=31920
I would like to run 255 on an 18x9.5 +28 with as little camber as possible. I also do not want to slam the car. Just drop it enough to make the wheels fit properly.
Could I make this fit?
Will the front have way too much poke if I don't use a silly amount of negative camber?
Cheeseballs is offline   Reply With Quote
Old 04-22-2013, 03:30 AM   #2
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
With a mild drop and near to stock camber the wheels will poke out infront about 1 - 1.5cm, and rear about 1cm.
If you are not going for a hellaflush look you should look for something around +40 when using an 9.5" wheel
Killerbee is offline   Reply With Quote
Old 04-22-2013, 03:47 AM   #3
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Misread
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-22-2013, 03:50 AM   #4
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Btw cheeseballs you running coilovers?
Omar GC
Instagram: 2jzus
Old 04-22-2013, 04:02 AM   #5
Killerbee
Killerbee's Avatar
Originally Posted by OmarGC View Post
You'll be able to do it cheeseballs, get a fender roller though
@Killerbee no offense, your fitment advice is waaaay off. 9.5 +40 is EXTREMELY mild fitment and very functional
I know,thats why I wrote "if you are NOT going for a hellaflush look"
And 9.5 with +40 and 1" lowered and almost no camber is about flush/just poking out 2-3mm, so dont see why this is an extremly mild fitment? (read his post, he wrote not slam, no crazy camber)
Old 04-22-2013, 04:15 AM   #6
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
I apologize lol after 14hr shift I missed the not
Omar GC
Instagram: 2jzus
Old 04-22-2013, 10:04 AM   #7
yohan04
yohan04's Avatar
Drives: Your sister
I'm running 255/265, +33 all around without no problems
yohan04 is offline   Reply With Quote
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 kimchangil424 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-03-2017 06:00 PM
ENKEI RPF1 IN 18X9.5 +38 Offset Silver color / 1300.00 / Brand NEW kimchangil424 Wheels and Tires 4 02-20-2013 06:59 PM
Tire shop wants to argue... 18x9.5 +38 with 255's Skurj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 02-09-2013 11:27 AM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
