Old 04-16-2013, 10:49 AM   #1
panman91
Drives: 2013 BRZ Limited, SSM
Low Race Ramps for Oil Change
Do you guys think these will have enough clearance to undo the drain bolt to change my oil. I remember seeing a DIY from rallispec and they changed the oil with similar ramps. What do you guys think?
[ame="http://www.amazon.com/Pair-Plastic-400lb-capacity-Ramps/dp/B002M3LVME/ref=sr_1_11?ie=UTF8&qid=1366123619&sr=8-11&keywords=mini+ramp"]http://www.amazon.com/Pair-Plastic-400lb-capacity-Ramps/dp/B002M3LVME/ref=sr_1_11?ie=UTF8&qid=1366123619&sr=8-11&keywords=mini+ramp[/ame]
panman91 is offline   Reply With Quote
Old 04-19-2013, 10:52 AM   #2
cwb48
cwb48's Avatar
Drives: 2013 FR-s Firestorm
If I'm reading it right, these ramps are 2.75" high. The car has about 5" of ground clearance, so you should have almost 8" with these ramps, at least at the front of the car. I think that I could get to the oil drain plug with that much room, but be sure that your drain pan has at least a 6 quart capacity- the one I had been using for years overflowed when I changed mine for the first time- only held about 5 quarts.
cwb48 is offline   Reply With Quote
Old 04-19-2013, 11:18 AM   #3
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Are there any bigger ramps people would recommend using?
JDKane527 is offline   Reply With Quote
Old 04-19-2013, 11:51 AM   #4
Foobar
SLO NO MO
Foobar's Avatar
I don't have race ramps, but I've been using Rhinos and I just have to put a 2x4 at the end of each one to make sure I don't scrape on it. Are you trying to stay with low profile ramps to avoid scraping?
Old 04-20-2013, 01:09 AM   #5
panman91
Exactly, but I think I might being going the topside oil change route using the Mityvac MV7201.
http://www.ft86club.com/forums/showp...19&postcount=1
Old 04-20-2013, 01:25 AM   #6
cnk
Drives: '13 DGM BRZ Limited
I just don't like the vacuum removal method for oil changes. There is always the chance that you will not be able to remove any debris/deposits at the bottom of the pan. At least with the drain bolt removed, there is a better probability of any debris/deposits being flushed out at the same time.
Think of it this way, would you flush your toilet by sucking the water out of the bowl?
cnk is offline   Reply With Quote
Old 04-20-2013, 01:25 AM   #7
ft_sjo
Drives: GT86
You'd be better off with something like this: http://www.ebay.com/itm/251254605772
Old 04-20-2013, 06:53 AM   #8
B L U E S L A T E
Drives: BMW E84
Those ramps look like replicas of the Tomioka Racing ones I've been using for years...
B L U E S L A T E is offline   Reply With Quote
Old 04-20-2013, 08:02 AM   #9
Gunman
Drives: 2019 Mazda Miata RF
These are stacked 2x10's, so they are roughly 3" tall, and give me plenty of access to the drain plug. (cheap too)
Gunman is offline   Reply With Quote
Old 04-20-2013, 08:26 AM   #10
xbreed
Drives: 2013 CBS BRZ Limited
I use rhino ramp that I bought at my local parts store. $40 or something like that and they work fine. Car just barely clears when stock.
xbreed is offline   Reply With Quote
Old 04-20-2013, 12:06 PM   #11
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I'd recommend this:
[ame="http://www.amazon.com/Torin-Professional-Profile-Aluminum-Service/dp/B00BEZKBKO/ref=sr_1_11?ie=UTF8&qid=1366473921&sr=8-11&keywords=aluminum+jack+stands"]Big Red Torin 1.5 Ton Professional Low Profile Aluminum Service Jack and 2 Stands, Jack: 21.85"l X 9.84"w X 5.91"h, Jack Stands: 7.4"l X 6.8"w X 10.7"h - Amazon.com[/ame]
PRO86 | WTCC | STL
Old 04-20-2013, 12:20 PM   #12
JDKane527
JDKane527's Avatar
Nevermind then, I already have 2 jacks and 6 stands and just wanted to pick up a set of ramps to make oil changes easier haha.
Old 04-20-2013, 02:28 PM   #13
OrbitalEllipses
Drives: Attitude
That's powerful imagery.
cnk (04-20-2013)
Recommended Car Ramps for the BRZ/FRS? mechaghost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 09-01-2017 12:41 AM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 04:43 PM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
Free Shipping on ALL Race Ramps Products @ JWM JWMotoring Mechanical Maintenance and Tools 5 10-04-2012 05:22 PM
Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 329 10-16-2011 08:51 PM
