Drives: Silver AT Limited
Recommended Car Ramps for the BRZ/FRS?
What do you guys recommend for a car ramp for the BRZ? I plan on using it to do oil changes.
Also do I even need one to change the oil? |
When In Doubt...
Drives: Slowww
I hope to hear a good answer for this. I'm thinking DIY ramps may be the way to go for us. I couldn't get my car up my friends ramps the other day yet they work fine for his even lower 5 series. Real shame that the BRZ front sticks out so much.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
Registered you sir
Drives: 99 impreza coupe
Get a fumoto valve. Ramps are always tough on cars with a low ride.
I certainly am planning to get a fumoto valve.
Site Moderator
Drives: Stuff
Any good ramps plus 2x4s should work. I haven't tested the ramps I have but I basically never use them anyways.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
Drives: WRB BRZ Limited 6MT
I've got a set of Rhino Ramps I bought a few years ago for my MINI. I had the BRZ up on 'em last week. It's snug; they appear to *almost* touch the front lip. They certainly won't work if you lower the car. If I find that the car sits a little lower once the suspension's broken in a bit, I'll just throw a 2x4 on the ground in front of the ramp.
[ame=http://www.amazon.com/Blitz-11903-Rhino-Ramp-8000/dp/B000AMMN9O]These[/ame] appear to be what I've got. |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
I've got Rhino Ramps and some boards. But I've been thinking of picking up some Race Ramps.
#10 | |
Corner Junkie
But for now, it's a couple boards and my faithful Rhino ramps. |
#11 |
Drives: 2013 FRS 6M, 2010 Camaro 2SS 6M
I've been using a set of the long, 2 piece Race Ramps along with a pair of the small, I think 4-inch ramp bumps (for lack of not remembering what they're really called). My Camaro is lowered probably 1.5 inches. The Race Ramps are awesome. A shorter set of ramps would just get pushed forward by the front underbody spoiler or cause that same piece to drag if backing up the ramps. If you plan on lowering the car at all, I highly suggest the long version of the ramps. I believe their website describes how to check if your car is too low for the standard length ramps.
For oil changes on my FR-S, I just plan on using an oil extractor. For decades, thousands, maybe millions of diesel boat guys have used and continue to use oil extractors. They work and they work well.
FRS bone stock. Camaro SS LSA forged, stroked, ported, nitrous plate w/standalone, dyno tuned old stock cube numbers: NA-473/437, N20-585/626 at the wheels, 3.90 RPM diff, ACT twin-disk clutch, 18x10 F14's w/NT05R 305/45's, and other supporting mods.
#12 |
Drives: '10 Nismo 370Z
I have the Takata LDS (low down slope) ramps. They've worked great for various lowered cars I've had. They clear the facia great and they raise the car enough to get a jack under. They discontinued them but there are copies or rebranded versions out there. I remember a friend of mine bought some that looked exactly like mine with a different name (Tomioka or Low-mioka) from EDO Performance, I'm sure you could google the info and find them. They look like this:
#13 |
Drives: ExigeS,M3,S2k,MCpe,MR2T,T4R,Sienna
Try these out. Use them with my lowered cars to good success.
http://www.griotsgarage.com/product/...ortby=ourPicks
Current: 19 GT-R[]17 M2[]17 WRX[]14 T4R[]12 NV2500[]07 Exige S[]07 S2k[]05 M3[]03 M3[]02 MCoupe[]94 MR2T[]93 MR2 T[]92 MR2 T[]91 MR2 T[]95 SC400[]
Gone but not forgotten: 04 STI[]05 MR2 Spyder[]04 S2k[]03 IS300[]90 MR2[] |
#14 |
The Race Ramp brand ramps are really nice but way too expensive. It's nice they give 10" of lift.
The Tamioka ones are nice but generally used to be able to get a jack under the car, they only have a couple inches of lift. Those ones at griotsgarage look pretty good for doing something like a quick oil change, 7" of lift and nice and compact. |
