Old 04-16-2013, 01:11 AM   #1
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
questions for Tein Monoflex owners
did you guys adjust the preload before the inital install
and also
did you load the suspension with the jack or just bolt it in while the car was in the air?
thank you.
dori. is offline   Reply With Quote
Old 04-16-2013, 09:45 PM   #2
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I did the preload on my Street Flex's on the car because I wanted more preload after testing it. Originally I set a 1/4 inch preload all around, but ended up with 3/8 inch preload.
To do the install I put the car on jack stands then use my floor jack to load the fronts to get the endlinks off then unloaded to remove the rest.
For the rear, I loosened the lower control arm joint bolt so that the entire arm can swivel easier. Then I preload the arm to unbolt the endlink, then unload to remove the rest.
Ironsquid is offline   Reply With Quote
Old 04-19-2013, 02:16 AM   #3
dori.
Señor Member
dori.'s Avatar
thanks
Tein MonoFlex Kenno Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-18-2015 01:17 PM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 09:48 PM
E85 questions Grishbok Engine, Exhaust, Transmission 17 08-08-2012 10:49 PM
How many FR-S/BRZ owners are former AE86 owners? DarrenDriven Other Vehicles & General Automotive Discussions 27 06-09-2012 10:35 PM
